Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Amana Refrigerator BR18* Freezer not really cold and running all the time
I have an Amana BR18* fridge with bottom freezer. The freezer is not getting cold enough to really freeze items. The freezer temp control seems to do nothing. The fridge works fine. I have replaced the defrost thermostat in the freezer and this did not fix the issue. Any ideas?
dutchman05
  • 487 Answers
SOURCE: Amana Fridge with bottom Freezer
either the switch or the temp sensor it broken. on the sears site you can get the part number
Posted on Apr 24, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
landsend
  • 1066 Answers
SOURCE: Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Posted on Mar 22, 2009
  • 15 Answers
SOURCE: freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
Posted on Jun 01, 2009
The freezer seems to be working but the fridge doesnt seem to be getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
We have a Amana BR18 Easy Reach bottom freezer. The fridge is turned up all the way, barely keeping food cold. The freezer is not freezing anything (ice, etc.). The freezer is still blowing cool air, but...
Low refrigerant assuming the compressor is always running and not being shut down by the thermostat.
You can hook up an ammeter to the unit to see if the current consumption is below spec, another sign of low gas situation since the motor is not working as hard as under normal conditions.
Jun 10, 2017 | Freezers
I have a amana bc20tw fridge with bottom freezer that is keeping cold in the freezer and cool (43 degrees) in the fridge. I checked the coils in the freezer and there is no ice or major frost. Also, the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Oct 15, 2010 | Amana ABB1927DE Bottom Freezer...
Not getting cold fridge or freezer side but at the bottom of the freezer its freezing
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 06, 2010 | Amana Refrigerators
Amana BR18 fridge/freezer. Fridge is cool but not cold, freezer is at about 20 degrees. Ice cubes are frozen but ice cream is soft. Any ideas?
you maybe blocking the circalation in the freezer the way you have things packed in there. Move large items away from where the cold air blows in.
Oct 04, 2009 | Freezers
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
97 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
