Question about Hotpoint HSS25GFP Side by Side Refrigerator
Fan or motor contantly running and howeling
Sounds like a fan is running for 3-5 seconds then pauses for 1-2 seconds then repeating almost 24 hrs a day. During the pause it howels like an air conditioner running. If you open the freezer door you can here the fan behind the ice maker is were the noise comes from and it continues while the door is open.
  • uncertain Nov 10, 2007
    Mine is more of a whining sound. Almost like freon whining through an expansion valve. Guess it could be a motor.
    Novelist:
  • 87 Answers
It really sounds like you need to replace the evaporator fan motor if it sounds like an a/c fan (if it sounds cyclic, metal on metal, screeching, or even like a light aircraft then the bearings are probably failed). The only addition I would make to this is when checking the fan motor with the back cover off you check for any undue ice build up on the coil which may be causing the howling (TO RULE THIS OUT). Hope this helps.
Posted on Aug 26, 2007
SOURCE:
My freezer door was left open. food partially thawed, motor making a loud clattering sound. after shutting the door, the noise stopped. it took>24 hrs for the food to refreeze
Maybe evaporator fan making noise. After leaving open for long time, there was probably significant frost build up on evaporator near fan.
Oct 06, 2018 | Refrigerators
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
I have purchased 3 new lamps. one lasted 900 hrs.
Your lamp is rated for 3000 hours. Is the fan working to cool the lamp? When you turn off the projector do you allow the fan to continue to run? If not the lamp is not cooling evenly and the lamp will fail. Th filters should be cleaned regularly and the vents be unobstructed.
May 14, 2010 | Toshiba TLPLMT70 Projector Lamp
Runs constantly. Coils extremely hot. Breaker kicks out infusebox
It sounds as if the compressor is overheating causing a large current draw throwing your breaker. If the coils are durty on the back....clean them..also clean the coils under the frig by the fan motor.
Aug 21, 2009 | Refrigerators
Bad Bulb?
the pins that protrude into the lamp compartment have a tendency to get out of alignment where the lamp will only make partial contact. It sounds like what youre describing.
Jun 15, 2009 | Televison & Video
Ge 36" MONOGRAM with bottom freezer, very hot on back inside wall
Make sure that the condenser coil is not dirty. If so clean it. Have you actually seen the fan in the back of the unit running? It has 2 fan motors. One on the inside of the freezer and one on the back of the unit. The one on the back not working will cause it to get very hot and so will dirty coils.
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Erratic goodman GMPN 100-4
sound like you have a bad fan motor
Dec 04, 2008 | Goodman CPLE24-1 Air Conditioner
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Hotpoint HSS25GFP Side by Side Refrigerator Logo
157 people viewed this question
Top Hotpoint Refrigerators Experts
jasbo
jasbo
Steve Allison
Steve Allison
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
