Question about Electrical Supplies
Advantages of Tubular filing - Electrical Supplies
One of the two blades appears loose inside the disposal and makes a lot of noise when running. Disposal appears to work fine otherwise.
If disposal works fine and doesn't vibrate the tubular drain pipes loose causing a leak, then it's ok to use.
The grinding sound is probably the bearings rusted.
The bearings are sealed from water, but eventually the seal breaks and bearing rust.
The 'loose' metal pieces attached to cutter disk were probably like that from beginning.
Put a vacuum cleaner hose into disposal and see if anything is rolling around inside.
I wrote ez disposal replacement steps from days when I worked apartment maintenance for you to keep on file.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
MY GARBAGE DISPOSAL IS WORKING BUT THE WATER IS NOT DRAINING. I TRIED THE ALLEN WRENCH BUT DONT HAVE THE CORRECT SIZE. CAN YOU TELL ME WHAT SIZE TO PURCHASE PLEASE
Use a broomstick handle down inside the disposal to wedge the cutter disk free.
Broomstick works just like allen wrench.
If cutter disk rotates, then clean out the tubular pipe that connects to disposal.
Remove trap under sink, and then remove tailpiece connected to side of disposal.
Clean out disposal.
I wrote tips for working on tubular drain pipes that might help.
Upvote the help.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
May 28, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal quit and both sinks are clogged , disposal won't work at all , is it a clog in the trap or is it the disposal
Clog is probably the trap.
Bail out as much water as possible, get some towels, and put bucket under trap and tubular pipes.
Remove two nuts off P-trap or S-Trap and drop trap down, and sinks will drain.
After clog is cleared, check disposal.
Check reset button on disposal.
If disposal is stuck, use wood boomstick to wedge open the cutter disk, or use allen wrench in slot on bottom of disposal.
If disposal will not work, check circuit breaker.
There are no repair parts for disposals.
For additional information about replacing disposal and permanently fixing tubular pipes:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on plumbing or any do-it-yourself project.
Feb 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage does not work.it makes humming sound for few seconds but does not rotate blades.
Use a broomstick handle to see if disposal blades rotate freely
If blades are stuck, use broomstick to wedge blades free.
If blades rotate freely, and motor does not turn on, then garbage disposal is broken.
Disposal mechanism cannot be disassembled for repairs.
Disposal will need to be replaced at some point.
I wrote tips for replacing disposal from days when I worked apartment maintenance.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connection at upper part of disposal with a hose.
5) Electric wire from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connection on side of disposal
In apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Always slap a good amount all around washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on disposal or any do-it-yourself project.
Jan 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal will not work untill i take the wrench and turn it a few times then it works fine but the next day i have to do the same thing and it works.Can i lubricate it.???
Garbage disposal mechanism cannot be disassembled for repairs.
Jan 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 is leaking from the bottom around what seems to be the electrical cord opening. any suggestions
Your disposal is rusted out and needs replacement.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal, or any do-it-yourself project.
Jan 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The garbage disposal motor works but the water will not drain from the sink. What can I do?
You have clog in tubular pipes under sink.
Start at P trap under sink:
Take a photo if necessary so reassembly is easy.
Remove both nuts on p-trap and trap falls loose.
Any tubular pipe that gets moved, has to be taken apart and reassembled.
So move as few pipes as needed to get job done.
Remove tailpiece going into disposal.
Clean out disposal, tubular pipes and trap.
Rubber washers are replaced with new washers.
Plastic washers are cleaned and re-used.
Tapered end of plastic washer goes away from nut.
Clean and reuse tubular pipes.
We always use a good slap of rectorseal on all tubular joints and washers when re-assembling.
This guarantees there will be no leaks.
Use rectorseal on every joint directly on the washer or joint just before putting on nut.
Jan 09, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Attach electric wire to new disposal, and push in reset button.
Attachment ring catches at three points, all three have to connect.
Remove old sink basket and clean sink opening.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Jan 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 9 disposal just stopped working. It is less than 2 years old. The blades turn freely, the reset button is in. It does not make any noise. Any other ideas?
1) Test disposal is getting electricity and switch is not bad.
Pull out switch so you can test wires:
Switch in ON position.
Use ordinary tester and test each brass screw to bare ground wire.
Tester should light up on each screw.
2) Next open wire connection at disposal and test & check wiring.
Be careful under the sink. Do not touch anything metal while working on live electricity.
Stay on completely dry surface.
3) In event of bad disposal, I wrote installation tips.
These tips do not include installing new disposal and taking old one back in same box as if it was a defective product.
Attach electric wire to new disposal.
Use new connector washer.
You might want to install new sink basket that comes with new disposal because it looks shiny and new.
Jan 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
