Hi i have a kenmore model #58585892.the problem:
disconnect the line to the water dispenser at
the water inlet valve on the back where the water supply comes in and try the
dispenser. if you hear the valve work but water doesn't come out, the valve is
bad. If you don't hear the valve, the dispenser switch is bad. If water does come out-
Your water line could be frozen in the door. You can disconnect
the line under the unit before it goes into the door at the bottom hinge. Push
the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
