Question about Dyson DC33 Bagged Upright Vacuum
How do I get the hose off so I can use attachmets
Need to clean corner and hard to reach areas, How do I get the hose unattached?
  • Dyson Master
  • 18,392 Answers
How do i release the hose from my dyson dc25
Hi there, it's Jack at Dyson.
Our Getting started guide shows how to use your DC25's wand and hose. Pulling the wand straight up to its fullest extent will disengage it automatically, ready for cleaning stairs and other awkward areas around the home:
If you wanted to remove the hose from the vacuum completely - to replace the hose with a new one, or to check for blockages - you just need to disengage the wand, remove the clear bin and cyclone, then press the hose release tab as you pull the hose upwards:
I hope this helps, but if you'd like any further advice you can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 10, 2014 | Dyson Vacuums
Tip
Extend a Vacuum's Hose "Lifespan"
There are several things that can lead to a fairly short "life span" on a vacuum hose. Hoses need to be replaced periodically anyway, but getting the maximum use means reduced cost for your investment. Common problems are: worn out hose, leaky hose, broken wire, loose connections, and of course, clogs.
Normal wear and tear may seem to be a problem that there's no help for, however anyone can reduce this on their vacuum hose. Some examples include:
Hang hose properly. Improper storage may promote wear on the hose and stress on the wiring. I recommend detaching from vacuum and wands, and hanging across two large hooks or hangars. This places weight upon two areas of hose, instead of just one.
Placing a hose sock on the hose will help reduce wear and tear caused by dragging back and forth on the floor, corners, and other surfaces. The heavier the fabric, the better protection.
Pulling the vacuum behind you while cleaning creates high stress on both the hose material and internal wiring. Indications of problems are loss of airflow/suction at end of hose for the first, and power nozzle not operating or intermittently operating. Avoid pulling vacuum behind you; move vacuum closer to the cleaning area to clean.
Loose connections are pretty much inevitable over time. The connections from hose to wand, wand to wand, and wand to power nozzle all are susceptible to wear and breakage. Replace hose and wand connections that are broken, loose, and/or blackened. Those things can cause bad electrical shock.
Clogs are often caused by a large item being vacuumed, but more often are due to a long, thin object being sucked up, sticking in the hose, and other stuff backing up against it. This will eventually cut off air flow and result in a burned out motor if not remedied.
Maximize your vacuum hose’s use by following the above suggestions.
on Aug 29, 2010 | Vacuums
What is 700a shop vac motor size
Craftsman 17765 canister vacuum cleaner is known for its assortment of power tools especially when it comes to cleaning jobs. It is designed to give you an easier, more effective cleaning. This vacuum cleaner delivers a high capacity reservoir, power and the versatility to swap easily between tasks. Craftsman wet/dry vaccums soaks even drosp of water on the floor with one of their 16 gallon wet/dry vacuum. It is also equipped with utility nozzle, extension wands, and dust bag that makes the cleaning process easier. The extension wands can clean the hard to reach areas like cupboards, corners, and bends. It has a large gallon tank that includes convenient drain port for easy emptying when the job is done.
Number of Tools:
Attachment Type:
Brush
Details and Capabilities
Cord Length:
Tank / Bag Capacity:
12 Gallons
Weight:
Hose Reach:
Cleaning Areas:
Car
Electricity
Horsepower:
5 HP
Voltage:
110 - 120 V AC
Power Consumption:
1210 Watts
Jul 09, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
How do you use the flip out function?
Hello. The flip out crevice tool is used for hard to reach areas such as corners and couches. To use, this feature simply flip out the crevice tool. Hope this helps!
Jul 03, 2014 | Hoover Handy Plus Sp60dsr6 Rechargeable...
Hi, my Dyson slim does not have any suction in the wand/hose. The vacuum itself works, just not the hose. I have unattached the hose, by unclipping it at the base, to make sure there are no rips or
Your changeover valve arm is more then likely broken or cracked. If so you will have to change out your under carriage assy. it's a pretty big job. I would recommend having an authorized Dyson service center change this for you as pretty much the whole machine will have to come apart. I attached a photo to show you the problem area.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 15, 2013 | Dyson Slim DC18 All Floors HEPA Bagless...
I disassembled the handle to attempt to remover the slip in upper half of handle. (did not figure out how to do tht). Now on re-assembling the handle, I cannot figure how the trigger is held secure to...
HI.These are the steps that may be helpful since you haven't describe the brand of your unit.Open the storage door at the front of the vacuum.Redmove the powered hand tool. Set it aside.Unsnap and remov any attachmets at the attachment storage area.Unclip and remove the wands from the vacuum and set aside.Pull the end of the hose from the hosed tube rack.Twist the other end of the hose from the dirt duck tube.Remove the hose.Unscrew the back of the handle.If you can't remove ,it is held tightly with nbuts located at the back of the compartment bag.Pull the handle carefully from the vacuum.If it has a non built cord wrap,slidethe wrap straight up from the handle too detach it before removing the handle.Once done assemble back.Thank you for choosing fiXYA.
Jul 31, 2011 | Vacuums
I just cleaned the beater brush area, turns fine, but it still will no pick up cat hair. Suggestions?
In mine, I found a huge clog between the vac hose (not the one for your wand) and the beater bar area. Hard to discover a clog here without removing the hose and getting in there with a piece of wire. Clue: If your wand is sucking fine, but not your floor part, odds are you have this problem. You might need a hex screwdriver to get the rear panel off for access; otherwise a simple fix.
Oct 24, 2010 | Hoover U6630-900 WindTunnel Bagless...
Won't work cleaning tools
There is a clog somewhere.
Most likely at any bends or where the hose enters the main body of the vac.
Make sure it's unplugged.
Romove the hose, stretch it out straight and see if you can see through it.
If there arer any hard piped bends try running a pipe cleaner through it to see where the blockage is.
Again, it's likely where the hose base meets the vac housing.
Needle nose pliers com in handy for pulling out string, hair, rig fibers pet fur etc.
Dec 06, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
How do you use and what attachments for upholstery cleaning with the Heritage II
Generic problem for all Vacuums
How do you use and
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Kirby has a spin brush that is round on the newer Kirby’s and it works on the suction from the vacuum and it fits on the end of the vacuum hose but it does not fit into corners very well or your can take some Kirby shampoo in the spray water bottle and use a kitchen scrub brush for the corners. Other wise you can use the actually Kirby Shampooer of which is very hard and unfriendly; the spin brush would be my selection. You can check with your local vacuum cleaner dealer in your area and also in the yellow pages. Also you can call the Kirby factory to see if they can direct you. The Kirby factory is listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Apr 18, 2008 | Vacuums
Dyson DC33 Bagged Upright Vacuum Logo
52 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
