Question about LG WM-2032H Front Load Washer
Wm2032hw error code on display "tE" needto know what part is defective to order replacement. Thanks
  • 489 Answers
TE error code means the thermistor has failed.  That part is located in the front of the drum next to the heater element.
Posted on Apr 28, 2008
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
What does the code te on the LG Tromm washing machine mean?
The TE error or fault code is to indicate a defective water temperature sensing thermistor. The thermistor cannot be repaired and will have to be replaced.
Sep 07, 2014 | LG Washing Machines
"PE errors lg washer wm2032hw" I replaced the
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
Sep 03, 2013 | LG WM-2032H Front Load Washer
LG Washing Machine WM2032HW displays LE error code & makes a grinding (best i can think to describe) noise during the wash cycle. Starts right after filling.
LE error also referred to sensor assembly- HALL switch and/or stator assembly. Replace the assembly by removing the back cover, removing the rotor with one bolt. You have to hold the rotor from turning while loosening the bolt, slide the rotor off of the spline shaft, take off 6 or was it 8, bolts holding the stator, unplug the two wire plugs, and, now, out of machine, unclip the hall sensor and replace.
Reinstall opposite way.
Here is the stator to order.
Here is the sensor to order.
Keep me posted!!
Jul 31, 2013 | LG Washing Machines
Samsung NE595N0PBSR range is giving error code "tE"
te error code is (touchpad error). you have to replace the touchpad assy. the board and overlay.
Apr 06, 2013 | Samsung NE595N0PBSR 30" Electric Induction...
I get a te code all the time and a he code from time to time.
from Lg this is the meaning of the codes.
  • The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
TE
  • "TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
    By the sound of this your heating system is malfunctioning and needs service.
    If you need more on this let me know, but it is either your temperature sensor or your heating element or control board.
Oct 02, 2011 | LG 24 in. LD-12BW5 Free-standing...
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error code tE, customer service recommended replacing thermoster, replaced but still getting error code. Can it be something else or does something have to be rest?
Ive looked through a service manual for your washing machine and that give the exact same fault and solution you mentioned (tE = Heater Error - The THERMISTOR is out of order)
Here is the service manual for you to look at:
WM-2277HW Service manunal
I had to scroll down to the troubleshooting section though but it has everything you would need to know in it.
I hope it helps
Regards
Mike
Mar 24, 2010 | LG WM-2277HW Front Load Washer
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
Oct 18, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG WM-2032H Front Load Washer Logo
430 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
