Question about Garden
Chainsaw Diagnose McCulloch chainsaw 2.3ci solid state ignition. What to check for proper function prior to installation?
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
revskank
  • 203 Answers
SOURCE: McCulloch chain saw pro Mac 10-10
if you are using McCulloch oil 40:1
Posted on Mar 02, 2009
  • 42 Answers
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
Posted on May 17, 2009
steve_lima
  • 181 Answers
SOURCE: I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
Posted on Jun 01, 2009
  • 109 Answers
SOURCE: how to check the spark plug is ok on a McCULLOCH
Chain saws are still two-cycle engines (gas and oil mix) and they foul the spark plug pretty rapidly if not in perfect tune. Remove the spark plug and re-attach the wire and let the plug contact any metal part such as the cylinder head. Make sure the gas petcock is off and the start switch is on. Pull on the recoil starter and see if you have a spark jumping from the center electrode of the plug to the outer electrode of the plug. Clean and re-gap the plug and try it again. If no spark, the center electrode could be broken up inside the ceramic insulator and you can't see it. Try a new plug. If still no spark, another component of the simple electrical system could be bad. If your saw has a capacitor, change that out also. Sometimes the small coil that rides very close to the magnets on the flywheel comes out of adjustment. Proper gap for that is a small piece cut from a cereal box and placed between the coil and flywheel while re-tightening the coil bolts. Do not let the coil scrape on the flywheel. If any of this has helped, please rate accordingly. Good luck.
Posted on Jul 06, 2009
Powermac 310 no spark
How do I test the ignition module out off the chainsaw? Or how do I know an ingnition module is working properly prior to instalation?
Apr 20, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
No spark on a 2116 mcculloch chainsaw
I think you need to replace the ignition unit as you seem to of checked everything else
Nov 26, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where can I get a McCulloch chainsaw overhauled please? my postcode is BR6 7RS.
I don't know if they have dealers or authorised service centers near London, but their phone number is 800-554-6723 in the United States. Their address is
McCulloch Power 9335 Harris Corners Pkwy Charlotte NC 28269 USA 9335 Harris Corners Parkway, Charlotte, NC 2826
Aug 31, 2011 | McCulloch Garden
I have a 14" Mcculloch
All modern chainsaws have electronic ignition, you should first try diss connecting the wire to the ignition switch, to rule out a fault with the switch, if still no spark check the gap between the the unit and the flywheel, this shouls be 0.3mm, if still no spark it will be a replacment ignition unit.
Jul 30, 2011 | McCulloch MCC1514 14Inch 15 HP Electric...
Hi, i have got a 240 trimac strimmer, and it wont start. it has fresh unleaded fuel, ( yes it takes unleaded). there seems to be no spark, even though i have changed the spark plug . all the conections...
I am afraid if it has no spark, then itis going to be a replacement ignition unit, it is a solid state electronic unit, so it is not servicable, to get to the ignition unit you need to remove the tube and the front housing, the unit is then screwed to the side of the cylinder.
Jul 21, 2011 | McCulloch Garden
Hi, I have an XL-12 that I bought new in 1971. It runs great, lots of power I am not one to look for trouble, I am curious how I might determine if the saw has points and condenser ignition or solid...
I believe that this machine uses solid state ignition, but has two elements--one is a trigger/charger coil and the other is the ignition coil. Like you said, if it ain't broke---. Parts for this are spendy--hope it outlasts the engine.
Dec 09, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I am trying to obtain a copy of McCulloch 338 Chainsaw Manual
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
Include your e-mail address in your request.
Apr 07, 2010 | McCulloch Garden
Looking for a manual for mcculloch pm 484 chainsaw. cannot start the chainsaw.
If the ignition and fuel supply systems are good that is correct. I was not able to find a McCulloch 484. Are you sure that is the model number?
Lou
Dec 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Husqvarna chainsaw no spark
Ignition systems on newer saws are a solid state all-in-one package. Disconnect the kill switch wire from the ignition pack to make sure that the switch isn't broken. Use a fresh spark plug to check spark with. An old one that is black inside is likely shorted. If still no spark, replace the ignition module. Use a piece of card stock to set the flywheel magnets to module gap, then tighten screws
Sep 11, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
