Desktop shut down in few seconds after getting display
My desktop shut down by itself in few seconds.But when I remove the 4 pin connector(square) next to processor on motherboard,its no longer shut down but I am not getting the display.
  • cutelovelyboy1980 Apr 30, 2013
    By the way I am using using PSVDC-MX motherboard.
    Please any one have an idea regarding this issue??
  • 519 Answers
Good day,
The problem you describe is probably due to a faulty power supply.
The four pin connector which you unplugged supplies power to the CPU, which means you will not be able to get a display with it plugged out, as there will be no power to your CPU.
The fact that the PC does not shut down when removing the 4 pin connector strengthens the evidence that your power supply is faulty. By removing the 4 pin connector you are reducing the power required from the power supply to the point where it is not 'overloaded' enough to switch off.
You can test this by plugging in the 4 pin CPU power connector, then unplugging something else, such as the DVD writer.
Then switch on your PC and see if it still shuts down.
If it remains on then the cause of your problem is definitely the power supply.
Replace the power supply and make sure it has a wattage rating of 400 watts or more. These power supplies are relatively cheap, and should be available at your local PC store for about $15.
Best wishes,
Graeme.
Posted on Apr 30, 2013
  • 565 Answers
SOURCE: Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Posted on Dec 26, 2008
  • 69 Answers
SOURCE: 920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Posted on Sep 24, 2009
  • 78 Answers
SOURCE: HP Media Center M7000 desktop powers down after 8 seconds.
before changing the motherboard just try to connect every thing without the case and then reset the bois then if the problem is still then it is the motherboard but befor you do this just it ia a crazy thing but will make all the terminals ground put the motherboard on the wall and make sure all the terminals is connected to the wall
Posted on Nov 08, 2009
SOURCE: how to install a sd card reader on a Dell
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Posted on Jan 31, 2010
joecoolvette
  • 5660 Answers
SOURCE: I need to know where to connect the three seperate
The eMachines C2685 uses an FIC VC37GV motherboard. (First International Computer, Inc.)
http://www.motherboards.org/mobot/motherboards_d/FIC/VC37GV/
Here is the motherboard manual,
http://www.ime.org.uk/pdfs/vc37_vg31_b1_eng.pdf
After you click on the above link, give it up to 30 seconds to download. This is a PDF file.
Barring you cannot download the file, I will state the connections for the Front Panel header on the motherboard.
(Plus state the page to reference to, in case you can download)
View the first link, with the photo of the FIC VC37GV motherboard.
As shown, Processor is at the top, Ram Memory slots are to the right.
The Front Panel header is located at the very bottom right corner.
It is parallel to the outside edge of the motherboard. There are two rows of pins.
(Page 12)
The Front Panel header has 5 pins going across the top, and 4 pins across the bottom.
The top row of pins are numbered Odd.
The bottom row of pins are numbered Evenly.
On the Top row starting on the Right side, going towards the left, the pins are numbered 1, 3, 5, 7, and 9.
On the Bottom row starting on the Right side, going towards the left, the pins are numbered 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HDD LED. (HarDDrive activity LED)
B) Pins 5 and 7 are for the Reset switch
C) Pins 2 and 4 are for a Dual Color Power On LED, if used.
Green goes to Pin 2. Yellow goes to Pin 4.
Otherwise Pin 2 is Positive, ( + ), and Pin 4 is Negative. ( - )
D) Pins 6 and 8 are for the Power On switch.
(PWR1, or SW1)
There is a small 3 pin header, just above the Front Panel header. (Page 12)
This is for a Power LED that has either two wires, or three wires.
The pins are numbered from Right to left.
Pin 1 is for the Power LED, and Pin 2 is for Ground, if using a two wire Power LED. (Not dual color)
Pin 1 is for the Power LED, and Pins 2 and 3 are for Ground (GND), if using a three wire Power LED.
(Page 13)
Posted on May 26, 2010
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
How do you get the hard drive out of a Toshiba Equium 7100D computer?
It's been a Long time since I have worked on one of these, so forgive me if my information is somewhat sketchy.
If memory serves the Left side of the case comes off. (Viewing the desktop computer from the front.)
There are clips underneath that need to be depressed, in order to remove this side cover.
From there with a flashlight, you should be able to view the other corresponding clips to depress, and remove the rest of the cover. Believe it lifts up so far, then slides forward.
At the Front Right side is the CD drive. There is a single screw you remove, and then the CD drive tilts up. From there you will see a single screw, that holds the harddrive in.
Once you are able to lift the harddrive up a bit, you wiggle the whitish colored plastic plug, side to side, as you pull out. This is a 4-pin Molex connector. It provides power from the power supply to the harddrive.
Sometimes this Molex connector can be QUITE tight, and hard to remove. DO NOT pull on the wires! If you use finesse, you can use a pair of pliers to wiggle it out. I advise using a Lot of finesse, as you can crush the plug. Sometimes it requires a bit of force!
The Molex plug looks like this,
http://en.wikipedia.org/wiki/File:Molex_female_connector.jpg
Then the 40-pin interface cable connector is removed. (Flat ribbon cable goes to this connector) Use a Lot of finesse here, as the tiny pins can be bent Quite easily!
Now the harddrive is in your hand, and you can examine it more closely.
The 4-pin Molex connector only goes in the harddrive, in one direction.
The top corners are tapered, and allow the plug to be installed only one way.
The 40-pin connector may be another story!
Looking at the connector itself, observe if there is a square lug on top. (Square plastic protrusion, emanating from the top edge of the rectangular plug)
This square lug lines up with a cutout in the back of the harddrive. It puts the 40-pin connector, in the proper position in the harddrive.
If this square lug is absent, don't fret when you go to re-install.
I will advise you the way to do it properly.
On one side of that flat ribbon cable you will see a faint Red line, or stripe. This Red line corresponds with Number 1 pin in the ribbon cable. Number 1 pin is on the side where the Red line is.
Viewing the back of your harddrive that you're going to install, (It is an IDE harddrive. Also referred to as EIDE, ATA, or PATA), note the pin locations.
All the way to the right are 4 pins. This is where the 4-pin Molex connector plugs into.
To the immediate Left are the Jumper pins.
To the Left of the Jumper pins are the 40, (39 actually), pins where the flat ribbon cable plugs into.
Number 1 pin goes towards the power connection.
The Red stripe on the flat ribbon cable, will be facing the 4-pin power connection on the harddrive.
If you have any further questions on this, please come back, and post them in an additional comment.
Oct 18, 2009 | Toshiba Equium 7100D PC Desktop
My dc7100 has a compact power supply with proprietary 24 pin plug. Pretty sure power supply is non-functional (shorted green to black and fan didn't come on). Is it possible to rewire a conventional ATX...
I just spotted this, hence the late solution. Perhaps this will help someone in the future.
Yes it is possible.
Observe the color code of the insulation of the wires.
1) Orange wires are 3.3 Volts
2) Red wires are 5 Volts
3) Yellow wires are 12 Volts
4) The Green wire is the Soft Power On wire
5) All Black wires are Ground wires. Doesn't matter which Black wire it is, it's a Ground wire.
(It isn't a Common wire. This is DC electricity, not AC)
These are your main voltages, and wires to be concerned with.
Fortunately all HP, (Or any proprietary computer manufacturer in that time period), did, was to change where the wires are placed in the 20, or 24-pin ATX main power cable connector.
They just moved the wires in the socket holes, didn't change the color code.
Solution is,
1) To remove the wires in the ATX power supply, main power cable connector
2) To remove the wires in the proprietary computer's ATX main power cable connector.
(NOTE*
BE SURE to make a concise, clear, drawing FIRST, of where the colors of the wires went in the proprietary connector, BEFORE you remove them!)
3) To reinstall the wires into the proprietary connector.
(Again. Following the color code of the wires you removed)
Removing the wires out of the 20, or 24-pin ATX main power cable connector:
Observe these photos, of a 20-pin ATX main power cable's connector. This procedure can be applied to a 24-pin ATX main power cable connector also. (Or a 20 + 4-pin ATX main power cable connector)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
(Also gives you information about the color code of the wires)
The middle photo shows you a view of the Front of the connector.
The photo to the right shows you the Back of the connector.
Where the wires go down into the connector is a Socket Hole.
At the end of each wire is a metal pin connector. A Male pin connector.
This metal pin connector is shaped like a tube on the end, and comes up to a square shape as you go up.
The square shape fits the square socket hole.
On one side of the square shape is a Tang. It's part of the square metal shape, and sticks out away from the square shape.
Resembles a barb on a fish hook.
In this crude illustration, let a small L represent the side of the square shape, and this forward slash - / represent the tang.
l/
This is an illustration from a manufacturer that supplies this type of metal Male pin connector,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002092166_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
A needle with the proper thickness so it won't bend, is inserted into the Front side of the socket hole, and is used to depress the Tang.
If you look down into the back of the connector, and into an individual socket hole with a bright light, and a magnifying glass, you will observe that the square socket hole has a small notch in one side.
This is where the tang slides down into.
It isn't easy to see from the front side.
The tang is depressed using the needle from the FRONT of the ATX main power cable connector, and the wire is removed from the Back side of the connector.
The metal pin connector's tube shape only goes up so far, then it turns into a square shape.
The socket hole in the connector is shaped to match. Tube shaped hole at the front of the connector, square shape coming on up to the back of the connector.
The square shape's corners, of the metal pin connector, keep it from coming out of the Front of the ATX main power cable connector.
The tang keeps the metal pin connector from coming out of the Back.
More information about the color code of the wires in an ATX main power cable connector, (Scroll towards the bottom of the page)
http://en.wikipedia.org/wiki/Computer_power_supply
Oct 16, 2009 | HP Compaq dc7100 PC Desktop
HP 1940 turns off after a second or two desktop appears with a message no signal detecked
no signal detected is displayed when there is no sync pulse detected by monitor. look in the monitor cable connector and see if you have a pin bent down. same at video connector at pc. if no bent or missing pin it probably bad in monitor itself. do u have another monitor you can hook up to pc? that could tell you which end is defective.(pc or monitor)
Aug 20, 2009 | Computers & Internet
Intel Desktop Board D865GBF/D865PERC 865G wont boot
First double check your front panel Connector it is laid out as follows
12
34
56
78
9
The power switch should attach to pins 6 & 8. The Pins for the reset switch should attach to pins 7 & 9 if its a two pin connector if it is a 3 pin Connector add in pin 5
The power LED connects to pins 2 & 4 The HDD activity LED attaches to pins 1 & 3.
If either or both of these LED's don't light up when the PC is running then reverse the pins for the respective LED(s)
Once the connections are confirmed
Check that the CPU is properly seated, the RAM and Video card connectors have lock down latches. Make sure they swing up and fully seat into the notches on the Ram modules and Video card
Make sure that both power connectors are attached there is a 20 pin ATX connector and a 12V connector (a 4 pin square connector) next to the CPU they should seat until the plastic clip clicks into place.
If the Video card you have chosen has a seperate power connection make sure that has been attached.
You should now be ready to give it a try again. If when you try to turn it on again you see a light on your Motherboard you know the board is OK. If not you may have a damaged Motherboard (Which you should get replaced under warranty)
If the light comes on but your PC tries to come up and it shuts down again immediately, you likely have either a damaged CPU or bad Ram modules. Which you should also replace under warranty.
If you have any further questions please post a comment here and I will try to help you further
Thanks
Dave
Nov 10, 2008 | Computers & Internet
Will not power on
This is a tricky problem. You would be thinking that if green light comes then everything is working fine. But that doesn't satisfy the system. Make the ATX power connector of SMPS(Single Mode Power Supply) is properly plugged in or not. The glowing of green light because of the small power connector (4-pin square connector) beside the processor fan. There is one more power connector i.e., ATX power connector. i guess its 20 pin. plug in properly and then try. If again the same problem occurs then you need to replace the SMPS itself.
Thank you........
Sep 28, 2008 | E-Machines eMachines Refurbished EMA...
Sudden power shut down/will not power up
Try these steps :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the Notebook doesnot start fine, we may have to need a Desktop monitor to check whether the issue is with the LCD, Graphic Card or the Motherboard itself.
Connect a Desktop Monitor to the VGA Port of the Notebook and press FN + F4 key to get the display on the Desktop monitor after the power button is pressed.
If you get the display on the Desktop monitor, the issue is with the LCD of the Notebook.
If there is no display either on the LCD or the Desktop monitor connected, the issue can be either with the Graphic Card or with the Motherboard itself.
Confirm if the Notebook is in warranty or not.
There are some known issues with few HP Pavilioin Notebooks installed with AMD Processors.
Try the link below and contact HP Chat Support if the Notebook is purchased in US to get it repaired for free :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01087277&dlc=en
Check the Product Number if it is listed among the once listed in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=c01300427#c01300427_
You can get the Notebook repaired for free if it listed among these numbers and is purchased from US.
Hope this helps...
Aug 13, 2008 | HP Pavilion dv6000z Notebook
FRIGIDAIRE GAS RANGE FGF378WCC
sl, because it't happening to both broil and bake the first thing I would suspect is the temperature probe. You should ohm it out. You can do this either at the board or at the harness connection in back. For the board, remove the back panel, there should be a 8 pin connector to the left of 3 relays. On the harness measure the resistance of the wires going to pins 1 and 2. On the shemantic it shows them being the 2 on the bottom. Should read around 1100 ohms at room temp. If you cant get a good reading on it there, Remove the probe from the inside oven, remove the screws and pull it out until the harness connector comes through, disconnect it and ohm it out from there. I don't think that both ignitors would fail at the same time so Im leaning toward the probe. Catriver.
Dec 11, 2007 | Frigidaire FGF378AC Gas Kitchen Range
Computers & Internet Logo
David Payne
David Payne
