Question about Sony HXR-NX70U Camcorder, NXCAM -
Cannot recognize usb device when I connect it to my computer (pc or mac)
SOURCE: compatability?
I set the USB to PictBridge mode (press home button, then main settings). Now iPhoto recognizes the camera and I can import photos.
Posted on Nov 15, 2008
craigjamesbt
  • 65 Answers
SOURCE: USB Device Not Recognized
try downloading the drivers from sony first http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C116935&fes=true&mdl=DSCW5 that is if you have already downloaded the proper usb drivers for your system in which case other usb device are still working also it is possible that the usb port itself has gone bad or is in conflict with another driver assuming your using windows to check this you can start by telling me which version of windows you are using but more than likely the proper camera drivers will solve the issue
Posted on Apr 26, 2009
  • 5 Answers
SOURCE: my PC cant find my PSP even im connecting with a usb device....
maybe you should try buying a new USB cable first. These things have sensitive wirings, so it might be possible that its the cable. find or borrow one from a friend to confirm if it is,or not the cable that has the problem.
mine has the same sickness,sometimes it connects,sometimes it doesnt,depending on how i hol the cord..its frustrating at times, so i went and bought a new USB cable. worked fine.
hope i helped!
cheers!
Posted on Aug 27, 2009
  • 8 Answers
SOURCE: When I connect my Walkman to the computer it says
use ipod in data dtorage mode when connected to your PC as if not connecting you might be having ipod driver you install it and you are on
Posted on Oct 17, 2009
SOURCE: I have my camera connected with the usb cable, but
OMG you are a genius!!! This solved my problem!!! Thanks Heather Weight
Posted on Feb 22, 2010
Windows 7 no detecta mi Ipod A1236, al ingresar a la busqueda de los dispositivos Windows me muestra el Ipod con un error que dice "Unknown Divice" no funciona correctamente, ya trate de...
iPhone iPad or iPod not recognized in iTunes for Windows
Si conecta su dispositivo a su computadora con un cable USB e iTunes no reconoce su iPhone, iPad o iPod, obtenga ayuda.
Cuando iTunes en su computadora no reconoce su dispositivo conectado, es posible que vea un error desconocido o un error "0xE". Si lo hace, siga estos pasos e intente conectar su dispositivo nuevamente despu?s de cada paso:
Aseg?rese de tener la ?ltima versi?n de iTunes que funcione con su computadora.
Compruebe que tiene el ?ltimo software en su Mac o PC con Windows.
Aseg?rese de que su dispositivo est? encendido.
Si ve una alerta de Confianza en esta computadora, desbloquee su dispositivo y toque Confiar.
Desconecte todos los accesorios USB de su computadora, excepto su dispositivo. Pruebe cada puerto USB para ver si funciona. Luego prueba con un cable USB Apple diferente.
Reinicie su computadora y iPhone, iPad o iPod.
Intente conectar su dispositivo a otra computadora. Si tiene el mismo problema en otra computadora, comun?quese con el Soporte de Apple.
If you connect your device to your computer with a USB cable and iTunes doesn't recognize your iPhone, iPad, or iPod, get help. When iTunes on your computer doesn't recognize your connected device, you might see an unknown error or an "0xE" error. If you do, follow these steps and try to connect your device again after each step:
  1. Make sure that you have the latest version of iTunes that works with your computer.
  2. Check that you have the latest software on your Mac or Windows PC.
  3. Make sure that your device is turned on.
  4. If you see a Trust this Computer alert, unlock your device and tap Trust.
  5. Unplug all USB accessories from your computer except for your device. Try each USB port to see if one works. Then try a different Apple USB cable.
  6. Restart your computer and iPhone, iPad, or iPod.
  7. Try connecting your device to another computer. If you have the same issue on another computer, contact Apple Support.
Feb 14, 2018 | Car Audio & Video
Tip
Mac won't recognize usb device
If your trying to connect a device via usb to your computer and it isn't being recognized; The best thing to do is go the manufacture's website of the device, look under download or support tab and download the latest version of the driver
The driver is what lets the computer recognize the device.
Download the driver, then double-click on the file so it will install itself on your computer. Once the driver is installed, restart pc, turn on your device and finally connect your cable
on Apr 17, 2010 | Computers & Internet
I am trying to trasfer a large amount of files from my macbook to a dell laptop. The mac will recognize the drive and i am able to backup and save files onto it, however when i plug the drive into the...
The problem most likely is the Dell does not recognize the MAC file format (HPFS), but the MAC will recognize the PC's FAT 32 file system.
First format the USB mass storage device using the Dell, format this device in FAT 32 not in NTFS because the MAC can read and write/copy PC format files but the Dell/PC cannot read MAC format files.
Then Safely remove this device, connect it to the MAC and copy the files onto this drive. When you connect this device to the Dell, you will be able to see the files.
Have fun.
Aug 13, 2010 | Iomega Computers & Internet
Usb not recognized on when I connect my flip ultra to any computer (mac or pc)... it has worked in the past on my mac and now is recognized by any computer... driving me crazy...
the camera has to powered and on ...and be sure you plug in the right kinda usb ...it needs to be a 2.0
so ..install a 2.0 driver to be sure you have one ..and after that with the camera powered ..plu one by one in each usb port..until it is seen in one...also look at the camera cause some devices need to confirm from them the connection via usb ...
it has to be seen ..if it's not ..change the cable it may be damaged..
Jan 30, 2010 | Pure Digital Flip Video Ultra Camcorder
Plugged alluratek ahdu350 to a mac, and the mac doesn't recognize
Firstly make sure You are not connecting it via a hub or extender but directly to motherboard ports [ ports "sticking out" of Your mac computer], secondly make sure the enclosure has no loose connections,
Please note devices like hard drives are real power hogs, just usb connection may not be enough power, You should have a power adapter You can plug to a wall outlet to give extra amps to Your device
Should it power on fully, make sure to go to system details [you go there by ressing a button in "about my mac" little window from the apple logo menu and check under usb listing if it is listed
lastly go to disk utility and check if the drive is visible, if it is not mounted it may need formatting
Jan 13, 2010 | Aluratek AHDU350 USB 2.0 Hard Drive
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
My harmony 1000 remote is not recognized by my mac computer
I had the same problem today on PC with the Harmony 1000. I noticed on the USB cable that mine came with it had a warning red icon (!). 1. install software then 2. plug in USB...
I didn't see this and I installed my software whilst the device was in the charging cradle with the USB cable plugged into my PC.
Before the software was installed I noticed the USB icon next to the Help on the remote screen, this dissappeared when the software finished installing the software and drivers.
I removed the remote from the cradle, pulled the battery out, unplugged the USB from the remote and computer, restarted my PC, powered on the remote, started the software on the PC and then plugged the USB into the remote and then the PC.. it was then recognized.
Mar 14, 2009 | Logitech Harmony 1000 LCD Touchscreen...
How to use a usb cable for the psp
Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
Scroll to the "Settings" icon on the home menu of your PSP.
Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
After that you can now transfer file from PSP to computer and vice versa...
Hope that helps..............
Sep 12, 2008 | Computers & Internet
Hard drive not being recognized
my book world is a network drive, you should connect it to a router / switch using an ethernet cable. if you use a usb cable to get it recognized on your computer it will never work
Aug 24, 2008 | Western Digital 500GB My Book World...
I cant put pictures onto computer?
you have several options.
1. see first what operating system you computer runs.
if it is vista or mac, it will be recognized as unknown device,
look for SSCAM100 or DCIM folder. you will then see the camera files in that folder.
2. you should also download the cd driver, the cd that comes with the camera, to your PC. this will help the connection be proper.
3. if you're using desktop, try to connect the camera at the back of your tower. look for a USB port at the back of the tower and connect USB cord to it.
4. make sure you're using the proper USB cable, the cable that comes with the camera. for your S630, it is USB cable type 2.
5. also, make sure before you connect camera to PC, camera is turned off, when the USB cord is properly connected, that is the time camera should be turned on.
6. when unpluggin the camera to PC, make sure that you are safely removing the device from the PC so you will not have future connection problems.
hope my suggestions work for you.
Jan 06, 2008 | Samsung Digimax S630 Digital Camera
Sony HXR-NX70U Camcorder, NXCAM - Logo
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
