Question about JVC Kdr330
AM mode does not work
Just installed used wire harness.everything hooked up correctly. AM mode does not work.
Caravan trailer wiring
some van don t have a ground wire. hook up to trailer put jumper cables to frame of trailer and van if works install a ground wire plug
Feb 05, 2018 | Dodge Grand Caravan Cars & Trucks
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
I am installing this on my 03 f-150 ..I am getting correct voltages on all of my wires in the h1 harness however im not using all of the wires in the h6 harness I cannot get the truck to remote start. It...
You need to program the remote starter. If you did not hook up tach, you will need to program it for either voltage mode or timer mode. It has been this way for many years. The installation manual is quite clear about this. You also need to ground the BLACK/WHITE wire. This is another common mistake on the installing persons part.
Jan 22, 2011 | C3RS915 SST Remote Car Start Vehicle...
I have an 09' Chevy Malibu and had an Autopage 603 remote starter installed. On the steering wheel are controls for the radio on the right and cruise control and info button on the left. After the remote...
Well the only thing I could think of is that maybe the bypass moduel that is used to bypass the factory antitheift system was spliced into the wires that are hooked into the info button, as the wires that are needed to bypass the PK3 wires are in the same location and may have compromized the integrity of the info button curcuit
Feb 17, 2010 | 2006 Chevrolet Colorado
Speakers don't work
If you had followed the directions correctly and the old speakers worked as well, take the new radio back for exchange
Jan 18, 2010 | 1990 Nissan Maxima
Wont play throught speakers only crakles everything hooked right maybe needs new wireing harness but everything works but sound
If everything is hooked up correctly, you may need to wire harness. It could be a bad capacitor in the audio outputs. Easy to try wire harness first. Sometimes turning off and back on again works.
Jul 08, 2009 | Pyle PLDVIN7 Car DVD Player
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
No Sound...Please Help!!
No wires are touching each other on door, harness etc.? disconnect each speaker from the harness one at a time, then use a 9v battery to test the speakers, if you get a feedback from speakers then they're good and wired properly. This should't be too hard. tell me where it goes from there...
Jul 30, 2008 | Clarion VRX755VD Car DVD Player
Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Jul 11, 2008 | JVC KD-G110 CD Player
JVC Kdr330 Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
