Question about Car Audio & Video
Single din dvd play jammed
My DVD player is now getting stuck half way as it folds in once the car is turned off when you turn the car on it doesn't move unless you pull on the screen to get it to a certain point then it continues to fold out itself unt you turn it or the car off then it gets stuck in the same spot and I have to repeat the process can I fix this?
  • 25 Answers
Well, you would need to look inside the device. Easy is to try to lube the guide rails with a dry lube. Liquid wrench make a dry lube, make sure its for electronic use. If that does not work then you must check the motor inside the until to see if its catching or slipping.
Some times it could be a return point issue. IT check this return the screen to the position of rest, (ie how it was when you bought it) Disconnect power to the unit.(disconnect one battery terminal is the eaiest way, or you can disconnect the wires) Wait about 5 mins, it needs to discharge. Hook it back up and try it out. If still a no go then try lube, then open it up, and look at the drive motor for the guide rails, are the teeth missing off the cogs, or is the shaft spinning without gripping. If it uses belts for this check them. If you get that far get some greese for electronics or some WD40 on a Q tip and try lubing it.
ALso might be losing power when moving, look at the connected wires while opened up.
good luck
Posted on Apr 30, 2013
SOURCE: XO Vision Bluetooth in-dash dvd player
you probably set the audio for 5-channel. In a 5-channel set up. Which it doesnt sound like you have there is a 5th speaker in the center of the dash dedicated for clear vocals. Play with surround options and i'll bet you can fix it
Posted on Dec 26, 2007
  • 216 Answers
SOURCE: DVD won't play and screen won't turn on
Do you have 12VDC going into player?
Do those dome lights can be turned on & off?
atdlee@netzero.com
Posted on Feb 02, 2008
rteemon
  • 578 Answers
SOURCE: we bought a car with micro vision dvd player
yes you can use any car video player as long as its as a video input that work
Posted on Jun 27, 2009
  • 7 Answers
SOURCE: DVD player car screen plays dvd in B/W , navigation in color
try checking the color system if its ntsc or pal
Posted on Jul 14, 2009
  • 84 Answers
SOURCE: I have a Eonon E837 no wiring diagram and when i
try changeing the yellow an red wires
Posted on Oct 04, 2009
Testimonial: "That worked great, thank you."
Ptid 8970 it says something flips down to load dvd but for the life of me i cant figure it out
probaly the whole face folds down check all around the edges for a release if not send me a pic
Feb 19, 2015 | Power Acoustik PTID-8970NRB 7 Single DIN...
Why does the dvd player not work while in park?
You r disabler wire is back wards. Normally this works the other way around, when in drive etc the front DVD screen should not play, only rear screens
Apr 28, 2014 | XO Vision XO1932 - Single-DIN In-Dash DVD...
Ouku 7" dvd player wont turn on
i have a ouku 7 inch dvd player when evere i turn on the truck the screem turns blue and it has a mute picture that binks on the left side i dont know wht it is can you help me
Sep 29, 2012 | Crown Ouku 7" Single Din Car Dvd Player...
Common Issues with Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
how can you hook up an aftermarket amp to your Ouku 2 DIN DVD player? i can't figure this out and iv looked everywhere.
Sep 24, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
Hi ive got an 12VCITY MA-7004 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i
hi, i bought <a href="http://www.12vcity.com/wholesale-car-electronics-car-dvd-2-din-car-dvd/13-car-double-din-dvd-player-buy-car-double-din-dvd-player-ma-dvd7004.html">12VCITY MA-7004</a> on 12VCITY official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.I think maybe you have connect the wrong wire and have bum out the built in amp.
Jan 11, 2012 | Car Audio & Video
Will only play about half the dvds that we put into it. once in awhile if you turn it off and on it will read the disc.
This sounds like the spindle is not spinning the media you may need a new motor, take the top off to see if when you press play the dvd spins this will confirm this
Dec 21, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
W200 will not play any type disk say "disk error"
The only fix i've found for this (without replacing parts) is to turn the unit off and back on and it will read the cd.
Aug 20, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Dvd plays initially, then stops midstream and won't let me ff or stop.
Laser is getting stuck or jammed or just all out malfunctioning. You need to get an external dvd player this will not be worth the cost of the repair. Sorry...no real fix other than installing brand new drive in your tv.
Feb 04, 2008 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Truck dvd player concept/pronto
Does it possibly have a reset button you could press with a paperclip? If not, try disconnecting the constant power wire for ....let's say an hour, and hooking it back up.
Nov 28, 2007 | Concept Slot Load Half-Din DVD Player Car...
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
