Can't install adapter card on atex
  • 3,799 Answers
More details please. Type of adaptor card, make of computer and reason you can't install it.
Posted on Apr 30, 2013
Wieson 1050 video card drivers
Do you mean how to update video card drivers? If so, see:
First of all you need to know what video card you have. If you have Windows and I assume you do go to Start > Control Panel (switch to classic view) > System click on Device Manager and in the list find 'Display Adapter'. The name of the driver appears. Make a note of it. Go directly to the website of your driver's manufacturer. Follow the instructions to download and install the right driver. Restart your computer to let it take effect.
Warning: this is the manual way to update. If you are not a tech guy, attempting to change video drivers could make your computer inoperable or cause severe problems.
As a result, you can rely on a drive detective software to help fix the driver issue automatically & accurately. This way also saves you time & energy.
Aug 22, 2012 | Computers & Internet
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
Graphic card location inside an E520
The Dell 520's manual can be downloaded here. The PC's motherboard optionally has a VGA Video Connector (integrated) as shown on Page 1 of the manual. If yours is equipped with this option, there is no graphics card installed - it is built into the motherboard itself. It can not be removed or separated from the PC.
Your PC may have a a separate video card installed into one of the expansion slots on the motherboard. Page 1 also shows this installed below the USB 2.0 connectors as the PCI Express graphics card.
Here's an internal view:
The video card in the picture is driving two standard analog VGA monitors (blue cable connectors) through a DVI -> VGA adapter (white and clear devices) this is connected to the video output connectors. If you look closely at the edge of the PC in the picture (directly above the USB & network cables) you should be able to see an unused VGA Video Connector (integrated). Most computer BIOS systems will automatically disable any built in video capabilities of the motherboard when a separate video card is detected. Check the manual for additional info about these BIOS settings.
I hope this helps & good luck!
Apr 17, 2012 | Dell Dimension E520 PC Desktop
How to change the graphics card software in acer aspire desktop....
You'll just have to know what kind of graphics card expansion slot you have. Older systems have AGP slots & newer ones have PCI-Express. This will help you decide which type of card to install.
Once past that, you would have to physically open up the CPU tower case while the machine is off & unplugged from the power. If it has an existing graphics card, it will have to be removed & the new one will be installed in its place. If you had been using onboard video, make sure to plug the monitor data cable to the NEW video card's VGA slot.
Everything practically plugs into ONE SLOT & only goes in ONE WAY. so if it does not fit, then it's being placed incorrectly. After putting it back together, just restart the machine & insert the installation CD that came with the new video card & follow the program instructions.
Please take note that it may require that the software and drivers previous display adapter will have to be removed first.
Aug 12, 2011 | Computers & Internet
Cant find where to install a wireless card internally to my dell inspiron 2600
You can't install any cards internally as there isn't any room inside. If you want to add wireless capability you'll need a USB wireless adapter which you just plug in to one of the USB ports. This computer also has PCMCIA (card-bus) slots, but that's older technology. USB adapters are much easier to find.
Jul 31, 2011 | Dell Inspiron 2600 Notebook
I have installed sims2 in my computer but once i try to run the game, this message pop up: (Failed to find any DirectX 9.0c compatible graphics adapters in this system! Please make sure you have a DirectX...
Is your card Direct-X 9 compatible ? Give me more details. Tell me what kind of VGA card are you using and your Pc's configuration (motherboard, CPU , RAM).
Jul 28, 2011 | Computers & Internet
I have a Dell Inspiron Laptop. I recently reformatted it. Now It does not recognize wireless connections. I cant connect to the net Can anyone help?
When you reinstalled Windows, Windows probably did not include a driver for your wireless adapter. A driver tells Windows how to interface with a certain device, such as a wireless adapter. You can easily download the driver online and install it. Once installed, restart the computer and you should again have the ability to connect to wireless networks.
I've gone to the Dell website for you and found the correct driver. Please visit this link: http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_PM_1525&hidos=WLH&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
On that website, I would first try downloading the first driver on the list. If that doesn't enable your wireless after a reboot, try the other ones. After the correct driver is installed, your wireless will be working again.
Jun 01, 2011 | Dell Inspiron 1525 Notebook
2wire wirelessa card
Believe u r talking about updating ur drivers for the wireless card...
right click on my computer--->click manage--->click device manager on left hand side on the window that opens---->click the + sign next to network adapters----> right click on wireless adapter----> click update driver
any driver installation is free or u can log onto the official website of 2wire... look for drivers matching ur wireless card... download & install
would suggest, while installing driver after downloading should plug out the usb wireless adapter.
Jul 04, 2009 | 2wire (1000-100016-002) Wireless Adapter
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
