Question about Fuji FinePix S2 Pro Digital Camera
FUJI S2 PRO
My Fuji S2 Pro shows a rotating egg timer when I show images in the play mode. Nor will the camera let me delete any pictures can you help please ? many thanks Kevin
  • Anonymous Mar 31, 2008
    i want the software to load the pictures on pc
    Champion:
  • 217 Answers
Maybe your card is already def.
Posted on Sep 04, 2007
SOURCE:
No image shows when I take picture
Usually the photo is displayed for a short period of time. Try the setup in the menu. There should be an option for previewing recent pictures.
Jun 20, 2012 | Fuji FinePix S2 Pro Digital Camera
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro New 4 Gb disk in cam prompts msg ''Card not initialzied.'' Have tried many things. None work. Help.
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Jun 25, 2010 | Fuji FinePix S2 Pro Digital Camera
When I take a picture the lcd shows all black? Is there a chance that I'm using the wrong CF card or is it a bigger problem?
Fuji had a problem with the CCD unit and put out a bulletin years ago to send them back and they would replace, but they no longer can do that, as the part is not made anymore. I had the same problem.
Mar 09, 2010 | Fuji FinePix S2 Pro Digital Camera
My fuji FinePix S2 Pro is processing images with a blush tone through out my images. What's wrong with it?
Could be a white balance setting or you've accidentally engaged a digital filter. You could try a camera reset. Go into the setup menu and scroll to "reset". This will take you back to the default settings.
Sep 22, 2009 | Fuji FinePix S2 Pro Digital Camera
Weird colors in viewfinder
Sounds to me like a CCD problem, which is a bad thing. CCD faults were quite common in the early S2's. It would be worth contacting Fuji about.
can you insert a few images into the thread to have a look at. Need more than one to check consistency of problem.
Sep 08, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 - image records in black
Could be CCD Failure ... known as ' Black Screen of Death'.
Have CCD cleaned at a reputable camera (not chain) shop and they'll test it.
Fuji were replacing units suffering this problem at one stage.
May 05, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji S2 problem
Err after a shot usually means bad AAA batteries. Change to alcaline or NiMH rechargable.
Dec 27, 2007 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
102 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
