Question about Desa International White Wireless Plug In Door Chime
Artslon bell push
Doesnt work
Why does my chime ring when next door has visitors
You're using the same channel. Change the channel the bell-push and the bell work on, by following the instructions that came with the bell and bell-push units.
Mar 21, 2015 | Cars & Trucks
Diagram for connecting a battery operated door chime to push button
IF you are going all elec,you need a door bell,bell transformer and of course the push button. This is all low voltage so phone wire will work.You are just using 1 pair of wires so pick a pair such as the blue pair.Wire from push button to transformer to door bell.It is not polarity senstive....simple to do
Mar 17, 2015 | Cars & Trucks
My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
Just a thought if the bell is wireless your diagnosis may just be coincidental, but look to at swapping out the battery. can you press the bell, say 5 times one after the other ok? Batteries sometimes recharge slightly between presses, maybe just pressing it twice once after each other doesn't work.
Nov 19, 2014 | Cars & Trucks
Will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Jul 17, 2012 | Home Security
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
Engine runs fine but car wont go. The main gear spins when i rev it but the clutch bell doesnt
When the engine is started the pisten goes up and down which in turn turns the engine shaft which then spins the clutch shoes around to a point where force pushes them out to touch clutch bell, clutch bell then spins spur gear. in order for spur gear to turn the clutch bell would have to turn to. If this is happening check the dog bones that go into transmission are all ok. Lift car of of ground and spin rear wheels to see if front wheels turn and spur gear.
Jun 12, 2010 | Cars & Co Radio Controled Atomic Warhead...
Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Jul 07, 2009 | Desa International White Wireless Plug In...
Packard bell utow co20
Please look on the case of the PC, fron back & sides. There should be a model number. (There is no such number you posted, Packard Bell UTOW CO20).
Mike
Jul 06, 2008 | Packard Bell DR724 Motherboard
Doesnt boot up
Hey, Blackchuck, try this
When you power up, try to get into BIOS and see what you get.
Let me know and we'll go from there.
Ron-
Nov 09, 2007 | Packard Bell Easy One Silver 2120 Notebook
Desa International White Wireless Plug In Door Chime Logo
37 people viewed this question
Top Desa International Home Security Experts
Steven R
Julian Pearson
Level 1 Expert
Halim Hartono
Halim Hartono
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
