Question about Dryers
Fisher and paykel de45f56e drier working but not heating. Would i need a new heating element and if so where can i purchase one from
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
  • 4 Answers
SOURCE: fisher and paykel 460 dryer not producing any heat
one of the 2 thermostats have failed, most have a reset button you can push pin into this will test if it is faulty, they are normally located near the heater element, you might also be able to tell with the reset one being slightly scorched45d764d.jpg
Posted on Aug 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: heatin element broken on my fisher & paykel dryer model # DEGX1
Try doing a Google search on the internet...put in your model number and make...look for parts
Posted on Sep 25, 2009
SOURCE: need a manual for fisher and paykel drier ED56
try here http://kitchen.manualsonline.com/ex/thread/view/idThread/2200997
cheers Sandy
Posted on Jul 02, 2010
hunter19_46m
  • 7482 Answers
SOURCE: my fisher and paykel dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 06, 2010
Fisher and Paykel oven hot heating on fan force
Possibly a burnt out fan element. You or a service person needs to test the element & wiring with a multimeter.
May 10, 2016 | Fisher and Paykel Ovens
Dish drawer not drying dishes
According to the manual, there is a cooperative effort with the rinse aid solution and the non eco mode. There nothing that says a drier circuit exists and if they are not drying then it is rinse aid or loading issues. However if you look behind the kick panel of the machine there is a plastic envelope with the technicians information on testing.
Jun 06, 2013 | Fisher Paykel Fisher & Paykel DD24SCTX6
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
No heat and dryer turns for a short period and then shuts off.
You have one of two problems, either the thermostat has opened or your element has failed. You will need to open up the drier and test both. I need a complete model number to cross and get you parts for this problem.
Get back to me so I can help you.
Sep 12, 2011 | Fisher and Paykel DE09 Dryer
I need operating instructions for Dryer Model No. DE45F56E which we bought new last October and have not use - but now I canot find operating instructions could you please email thanks
was using dryer, paused the cycle and took out clothes, now the dryer wont work and every time i press the start button it beeps at me three times really fast. there is a red flashing light left of the lock button.what is wrong and how do i fix this????
Jul 20, 2011 | Fisher and Paykel Dryers
Fisher Paykel DEGX1 no heat, therm tripping - used multimeter
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
May 31, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heatin element broken on my fisher & paykel dryer model # DEGX1
Sep 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Fisher Paykel Heating Element.
you have eather a bad timer or bad motor .
Nov 08, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
Top Dryers Experts
