Question about ASUS P5LD2 Motherboard
Bios update need bios update
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
When biosagentplus website scanned my pc, saying my bios was unknown but it can be updated.is it true? thanks hyui
NEVER NEVER
DONT UPDATE BIOS EVER
IT WILL MORE OFTEN DAMAGE YOUR BIOS
DONT..... PLS DONT UPDATE BIOS EVER.....
NO NEED TO UPDATE BIOS FOR ANYTHING.....
THE EXISITING BIOS IS OK......
IT JUST READS YOU HARDWARE AND BOOT FILES
EVEN AFTER UPDATE IT WILL DO THE SAME....SO NO NEED
DONT UPDATE BIOS OR FOR THAT MATTER ANY FIRMWARE ON ANY HARDWARES NEEDS NO UPDATING....THEY ARE MFD TO WORK THAT WAY....THEY SHOULD REMAIN THAT WAY
DONT MAKE THE MISTAKE OF BEING ADVISED BY ANY WEBSITE THAT TELLS YOU TO UPDATE FIRMWARE / BIOS....IT'S ALL USELESS
Nov 29, 2010 | Computers & Internet
Need a bios update
To update the Bios, you have to know exactly the Manufacturer, the mainboard model. You have to go to the Mainboard manufacturer Support Site to download the precise Bos file for the mainboard for the update.
A word of advice, updating the bios is not for the "novice" users. There are many precautions you need to heed before doing a bios update. Any errors during Bios update might render your mainboard useless.
Nov 01, 2010 | Computers & Internet
Dear Friends i have used in gigabyte mother board model no:GA-G41M-ES2L the problem is how i update my bios now is currently used in old version 1.0 but i have to update my bios pls tell me and solve...
you need to flash the bios .
download the new bios from gigabyte website and follow their instructions on how to update bios. be very carefull when doing this because if done incorrectly it would render your motherboard useless permanently .
in my experience if your m/b is working its best not to update the bios only time i would update the bios would be if the new bios update has new features that i really needed . if not i would not really flash the bios .
Aug 02, 2010 | Gigabyte GA-G41M-ES2L Motherboard
No update bios found for p4i45d bios 1.20
Why do you need a bios upgrade. Unless there is a specific problem you don't need to update the bios. Updating the bios and be very dangerous if you don't know much about computers. Also unless there is a specific problem with the motherboard they won't make any bios updates.
Nov 27, 2009 | Asrock P4I45D Motherboard
Pavilion dv6628us bios update on battery power?
You cannot update your BIOS on battery power because if your battery dies while updating the BIOS, your PC will not function at all because the BIOS would be corrupt. So your PC won't take the chance of that happening.... smart PC..
Your PC doesn't recognize your A/C adapter?... then you either have a bad A/C adapter, or a bad charger port on your motherboard. either way you will have to buy one or the other in order to update your BIOS.
you shouldn't NEED to update your BIOS... u can live with an older version
Sep 11, 2009 | HP Pavilion dv6628us notebook
BIOS update
It is not necessary to update your BIOS if everything is working correctly.
Jun 29, 2009 | ASUS A8N-VM Motherboard
E-Machines etower 533id PC Desktop NEED BIOS UPDATE
You only need to update bios settings if and when you get severe problems. The bios supplied with any computer is good for life of pc. normally.
But if you wish to update, visit the manufacturers site and download the bios flash utility.(that is the pc manufacturer not the bios manufacturer)
Jun 21, 2009 | Computers & Internet
Updating BIOS
Different computers different files
You need two files to do the Job read instructions carefully
1 is for bios the other is the program that install it
Aug 30, 2008 | Intel Motherboard
ASUS P5LD2 Motherboard Logo
19 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
