Question about Kitchen Appliances - Others
Instruction manual TR-895 B - Kitchen Appliances - Others
Advance instructions
No, the last tr is also your first tr on your next row... " tr in last stitch, turn, ( this counts as first tr.) so if it calls for . .. turn, tr in same or tr in 1st or 1ch it is actually your second tr.... but for counting sake call it 2 if I haven't confused you more.. lol or need more clairification (can't) spell ..... just ask
Dec 08, 2013 | Video Game Consoles & Games
Need installation instructions to replace SW-6538, range sensor, for 2005 ford focus
only have 2002 right now
SECTION 307-01: Automatic Transmission/Transaxle 2002 Focus Workshop Manual
IN-VEHICLE REPAIR Transmission Range (TR) Sensor Removal
  1. Disconnect the transmission range (TR) sensor electrical connector and the selector lever cable.
  1. NOTE: Failure to hold the shift lever while loosening or tightening the manual shaft lever will transmit rotational torque to the TR switch and shift mechanism.
    Remove the TR sensor (automatic transaxle removed shown).
    1. Remove the manual control lever.
    1. Remove the bolts.
Installation
    Install the TR sensor (automatic transaxle removed shown).
    • Loosely install the bolts.
    • Install the manual control lever.
  1. Using the special tool, align the TR sensor and tighten the bolts.
  1. s2y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use air tools on this bolt. Hold the manual control lever while tightening the manual control lever bolt, failure to the manual control lever shaft could occur.
  1. s2y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Check the manual control lever is in position "3" same as "D" position.
    Adjust the manual control lever to TR sensor "D" position.
    1. "1" Low 1
    1. "2" Low 2
    1. "D" Drive
    1. "N" Neutral
    1. "R" Reverse
    1. "P" Park
    • When in position "D" the marks on the manual control lever line up with the marks on the TR Sensor.
  1. Connect the selector lever cable and the TR sensor electrical connector.
May 23, 2011 | Ford Focus Cars & Trucks
Where can I get a manual for GE 25802GE3-A. thanks
The 25802 is an extra handset for a 25825,826 or 895 system. Here are the instructions for installing the handset.
http://www.home-electronics.net/USER-GUIDES/25802_DOM_EN_CL_IB.pdf
For the manual to the system, you can go here http://www.home-electronics.net/search-Results.asp?phone=cordless&lang=English&region=United
lThey have the 825 and 826 but not the 895. Maybe you can find something close.
Carl
Mar 07, 2010 | GE 25952 Cordless Phone
Lost manual chefmate tr440
You can get one here. There is a $1.85 charge for the whole manual but you get the manual instantly. Hope this helps.
http://www.scribd.com/doc/18027869/Chefmate-Bakery-Oven-Model-TR440-Instruction-Manual-Recipes-TR-440
Aug 15, 2009 | Chefmate TR 7000 Bread Maker
Chefmate tr 7000 bread maker
try http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Oct 16, 2008 | Chefmate TR 7000 Bread Maker
Lost breadman instruction manual
I have TR-444 manual if that helps let me know
frcs68@hotmail.com
Jun 10, 2008 | Breadman TR444 Bread Maker
Kitchen Appliances - Others Logo
19 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
