F5 f6 brightness buttons not working help?
Hi I have an asus laptop and I usually press shift f5 or shift f6 to make my brightness higher or lower but today none of that is working, I also tried restarting and everything It didn't work though :( please help?
  • 7,627 Answers
You didn't post the Asus Model or the OS you are using? Have you done ANY updates? Have you tried a System Restore to a date before this issue? When you restarted did you remove the battery?
Posted on May 01, 2013
SOURCE: Function Keys Don't Work
ANY HELP PLEASE??? Have Compaq N410c can anyone tell me how to activate the wireless button / link...press function button and F2 and doesn't lite up ...any ideas how to get this damn machine wireless...
Posted on Jun 22, 2008
SOURCE: unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Posted on Nov 28, 2008
Solo4665
  • 53 Answers
SOURCE: My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Posted on Dec 11, 2008
SOURCE: ASUS X80L has no display
i have the some problem with my asus x80l, it won't turn on when i press the power button but it does when i tried to press another button and then it has a very dim display
Posted on Apr 18, 2010
  • 10 Answers
SOURCE: Hi,my laptop is Asus X42J,the
Hello there. Follow my steps:
  1. Go to support.asus.com
  2. Select "Download" (if you don't see a "Download" button due to being in another language, select the last item from the main menu and select "English)
  3. Find your laptop model using the wizard
  4. Select your operating system (to determine whether if it's a 32bit/64bit, go to your start menu > right click on "Computer" for Windows Vista/7 or "My computer" for Windows XP and look for a text which says "XX bit operating system)
  5. Go to the "ATK" tree
  6. Download the "ATK Hotkey Utility" thingy and install it.
Posted on Mar 16, 2011
Im holding the Fn and f5 key to brighten my screen but its not working
The icon colours should match ...usually blue and you have to tap the brightness up button repeatedly as it is incremental.point worth noting.if the power supply is not connected the battery save option can disable the brightness of screen to stretch out the life of battery between charges.
Mar 22, 2015 | Samsung NC10 Netbook
Brighten lcd screen
OK, you are part right. The Fn key on most laptops is written in BLUE. This corresponds to the BLUE legends on various keys on the keyboard. MOST laptops have a pair of generic symbols for the screen brightness up and down . The brightness UP is a blue square (rectangle) with a large asterisk inside. The brightness DOWN is the same except it has a small asterisk inside. You will usually find these two keys as a secondary function of a function key.
Example: On my ACER netbook Fn+F6 = brightness UP and Fn+F5 = brightness DOWN
Nov 13, 2013 | Acer TravelMate Computers & Internet
When I connect my ASUS monitor to my Dell laptop the ASUS monitor displays nothing instead it says "No Signal"
Hi
You do not say if your laptop screen is working or not or why you want to use an external monitor.
Assuming the laptop has no fault and boots properly, to send the laptop image to an external monitor, once you have booted into Windows, press and hold the Fn (function) key bottom left of your keyboard, near the Windows Logo key, then simultaneouly press the Function key (above the numbers) with the image of 2 monitors, 1 dark, 1 bright (often the F4, F5 or F6 key).
If the laptop's screen is faulty and the above procedure does not work, there may be damage to the graphics card which will probably require specialist repair.
I hope this helps.
Aug 27, 2011 | ASUS MW221U LCD Monitor
Can't increase brightness, pop-up for brightness control does not appear when you press Fn and F6 only when Fn and F5 but the brightness is at minimum.
You need to install the hot key software. You can also change the brightness by going to power options.
It's the driver is available at http://uk.asus.com/product.aspx?P_ID=IGLKH3VUoGlp8KE1 it's the 1005PE version but it works fine, just go to the download tab & select the OS you use.
Mar 11, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
The fn key seems to be stuck on in order to get regular results, example f5 refresh, I have to press fn-f5, otherwise I get the below results abcdefghijklmnopqrstuvwxyz normal esc ok f1 monitor options...
Boot To BIOS and ensure you reset factory Defaults.
If no change try this:
http://www.fixya.com/support/r4510515-when_try_type_ampersand_get_quotation
Oct 05, 2010 | Dell Inspiron 1501 Notebook
How to adjust the brightness on my sony vaio pcg-k17?
To adjust the brightness control, press Fn + F5 and release, plus the RIGHT ARROW or LEFT ARROW keys to increase or decrease the value.
On most notebook computers you can use the Fn+F5 keys to lower the screen brightness level, and the Fn+F6 keys to raise the screen brightness level.
May 18, 2010 | Sony VAIO K45 Notebook
THE FUNCTIONS OF F1 - f12
http://www.netbook3g.com/wp-content/uploads/2009/01/asus-eee-pc-900hd-900ha-keyboard-t.jpg
F1: sleep
F2: Wifi
F3; lower brightness
F4: higher brightness
F5: switch to external monitor
F6: uhh not sure... stock market? lol
F7: mute
F8: Down volume
F9: Up volume
F10: F10
F11: Num Lock
F12 Scroll lock
Apr 06, 2010 | ASUS Eee PC 900HD Netbook
My lcd is too bright
Screen Brightness can be adjusted in either of these 2 ways....
1 Power Options(Start >Control Panel>Power Options)
Or by presing FN+ F5and using Function Key (FN) + F5/F6. F5 will decrease the brightness, F6 will increase it...
If neither of those work, Click
>Start
> Preferences
>Power Management
http://img205.imageshack.us/i/screenshotremotedesktopft2.png/
Mar 03, 2010 | ASUS Eee 4G Notebook
Cant turn the brightness down on my asus netbook
You should be able to use the "FN" key and "F5" key, press and hold the "Fn" key then while holding that key, press the "F5" key to decrease the brightness. Use the same(Fn) key and "F6" to increase the brightness.
Jan 02, 2010 | ASUS Eee 4G Notebook
My computers f1 to f10 and my five and six are ot working
If you are referring to the F5 and F6 keys, please find the functions of these keys as under, please check if you are able to perform any of the functions mentioned hereunder.
F5
you can use this key to refresh the active window of a webpage or Windows Explorer.
In Microsoft word when you press this key, you can go to Find and replace window.
Pressing SHIFT + F5 is helpful for moving to previous revision
To restore the windows size you can press CTRL + F5
To quit the Word program you can simply press ALT + F5
F6
You can change Frames or pane in Windows Explorer or a Webpage by pressing F6.
In Microsoft word
, pressing F6 will go to the next pane or frame.
SHIFT + F6 will take you to the previous pane or frame.
CTRL + F6 will help you to go to the next window.
CTRL + SHIFT + F6 can be used to go to the previous window
Hope you find this information helpful.
If you find this information helpful, please do not forget to leave your comments and ratings.
Thank you for choosing Fixya
Dec 19, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
