Function manual of sony trintron 27exr15
Sony kv-27exr15. Pls tellme which is the systam in IC no M37100M8-115SP?
    Top Expert:
  • Televison & ... Master
  • 75,289 Answers
Yes. That is the main system control IC.
Posted on Apr 30, 2013
welcomejee
  • 10594 Answers
SOURCE: Sony KV-BZ212N50 schematic diagram
Service Manual of KV-BZ212N50 is available on charge basis.
Posted on Jul 29, 2008
  • 4234 Answers
SOURCE: sony model # kv-36xbr800
The standby light should be blinking a repeating count with a 2 second pause between counts. Can you post hte count here please? That will help to determine the effected circuit and the solution.
Thanks,
Dan
Posted on Aug 01, 2008
jerryg50
  • 1689 Answers
SOURCE: regulator ic of sony tv kv-g21c1
I am not familiar with the particular model of Sony TV that you have. I can answer genericaly:
There are a number of voltage regulators typicaly used on TV sets. These are usualy IC devices, or a complete descrete circuit. The purpose of these are to regulate voltages that are used to operate various circuits. Most sets can typicaly have anywhere from about five to maybe even a dozen or more throughout the set, depending on the sophistication of the model.
The regulators, like any part in the set can fail with age and use. Sometimes they are damaged from other components failing, or when a regulator fails, it can damage the circuit areas that it is suppying. When the set is being service, the tech must check for other failed parts.
Jerry G.
Posted on Sep 01, 2008
SOURCE: NEED OWNERS MANUAL FOR REPROGRMMING CHANNELSKV2185P
I didn't solve problem Ineed a owners manual for sony trntrn tv kv2185p
Posted on May 28, 2009
SOURCE: old user manual sony tv KV-29ST1
I have a sony kv-27fs200 tv that takes a very long time to come on, about an hour or more.
Joel.
Posted on Aug 25, 2009
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
Cual es el control remoto de tv sony modelo kv-27exr15
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 11, 2014 | Televison & Video
Trinitron KV-27EXR15 speaker settings
If the mute function is set to OFF, there should be sound, as you increase the volume level. If there is no sound, check the speaker and audio output circuits.
Jul 11, 2013 | Televison & Video
RCU410MS code for Sony Trinitron KV-27EXR15
get a SONY universal remote number RM-U302 it needs no codes just press the SONY item say in your case TV and the remote will self calibrate to your type
My sony trintron 21" the bottom half is black i
solution
step 1 : Now at first test your fly back transformer
step 2 : A.C. transformer out put voltage test
step 3: Vertical yoke coil adjust
Jul 30, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My sony trintron 21" bottom
RE-SOLDER VERTICAL SECTION & CHECK IT.ALSO CHECK PIN CUSHION SECTION.
Jul 29, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I have a Sony Trintron also - similar model to the
looks like a horiz.output transistor is shorted.check it...
Jul 08, 2009 | Sony KV-32S45 32" TV
Sony 32" Triniton TV. Will not turn on.
The four blinks indicate a vertical deflection problem. I would suspect either bad connections on the vertical IC or a defective IC. This IC is a small flat IC with about 9 pins or so and should be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC.
You may also need to replace some capacitors in the circuit, but try the IC first and keep us updated.
Dan
Mar 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
