Grohe service code 31
What do Service 01, Service 30 and Service 31 mean on a Grohe Wireless shower? I've also recently had "PRIMING" come up. I've tuyrned the base unit off since and I am following these instructions from the web "first try turning the base unit off for 45 minutes to reset. if that doesn't work than you need to re-register the unit. remove the data hatch lid to the remote. is the light flashing red than you will need to get it serviced. if green or flashing green than press + and pause to get to setup. press + to get to register. press the reset button under the data hatch on the base unit until flashing then press pause. press + and scroll through to exit then press pause. you should then hear the unit priming. the shower should be ready." Is there a service manual that I can get hold of to help me out - I'm quite technically astute (I work in IT) and happy to get my hands dirty with plumbing and other bits and bobs.
SOURCE: Can't get sound from the wireless subwoofer
I had the same problem and it turned out that the directions are very unclear. You need to not only press the ID/SET button on the wireless system, but also on the wireless subwoofer itself. That solved my problem.
Posted on Oct 04, 2007
SOURCE: on/off button flashes green, unit will not turn on manually or with remote
PRESS THE TV BUTTON OF YOUR REMOTE CONTROL FOR FIVE SECONDS AND YOUR TV WILL TURN ON.
Posted on May 30, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Posted on Jul 18, 2008
  • 3197 Answers
SOURCE: Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on Aug 25, 2009
pineworks
  • 4041 Answers
SOURCE: Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Nee installation manual for a special care shower to take apart a Greohe Grohmix thermostatic/pressure balance mixing valve, model #34.421. this is a discontinued model. I've been able to get
Grohe or AKA Hans Grohe will send you a manual if necessary or if you spell it right you can find a copy online to download. I imagine you missed removing a retainer.
Sep 09, 2014 | Water Heaters
I've just installed a grohe mixer shower/bath
Did you account for wall thickness?
Dec 17, 2012 | Water Heaters
Grohe avensys dripping
Hi Bryan,
The leak you're seeing originates at the hot / cold water valve(s) itself. Most newer homes have valves that automatically adjust the temperature of the water to prevent scalding. Your Grohe Avensys, like many reputable makers, have warranties on their products and may make replacement parts available for free - if you are still under warranty - by call their customer support lines.
Generally, you will not be able to get free replacement parts at a hardware store, plumbing supply store, etc. You must call the manufacturer directly. Of course, you will have to pay for these parts at those retailers - if the valve is out of warranty, been replaced by the manufacturer under warranty previously, etc.
Your first step will be to identify the valve model. This information may be near the manufacturer's name - or may require locating the manufacturer's web site for visual comparison. Either way, you'll probably need to contact the customer service representatives to get help with replacement parts. They should be able to select the parts that you need to solve the problem and provide them along with printed removal & installation instructions.
Contact links for Grohe USA & Canada
Contact links for Grohe UK
I hope this helps & good luck!
Aug 31, 2012 | Home
I have a wireless Grohe shower that keeps dripping hot water constantly
Your mixing valve(faucet) has a bad valve and is allowing the hot water to bypass and leak thru shower. You should replace the bad mixing valve or the faucet to repair and stop the leak.
May 10, 2011 | Grohe Home
Grohe wireless HP electric shower has service code 01 on main switch in shower, and no flow of water.
I had the same Service Code 01. The solution is simple. Switch off the power for the shower for a minute or so usually located outside of the bathroom. Switch it back on and you should hear the unit (if it's close by) resetting itself. Switch on the shower and it will tell you to wait, then with a bit of luck it should wizz into action.
Sep 14, 2010 | Home
What is service code 1 for a grohe wireless shower
Jan 04, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
Electro Med Services...
