Question about Yamaha YST-SW205 Subwoofer
Replace subwoofer how you open to replace them
  • Yamaha Master
  • 17,095 Answers
If the speaker enclosure is wood, and there are NO screws, you need to use a table saw to cut the back off.
Posted on May 13, 2013
What model sub woofer can replace JVC SP-PW100?
open corel, at top click on about- click on activate and enter code
Sep 09, 2014 | JVC SP-PW100 Subwoofer
Subwoofer stops working at times and will not work.have had it about 4 or 5 days just started doing it today
many pple have the same problem.... that subwoofer stops working sometimes when playing music or something else... I also faced the same problem .... I did the following things..
open your subwoofer. checked all connections for any loose contacts... and then check the wire of the main speaker.....
IF YOU FIND DIFFICULTIES IN OPENING OR IF YOU DONT KNOW MORE ABOUT THE INTERNAL PARTS OF SUBWOOFERS.. THEN DONT TRY TO OPEN IT.. YOU MAY CAUSE DAMAGE TO IT...IN THIS CASE :
GIVE YOUR SUBWOOFERS TO THE SERVICE CENTRE FOR REPAIRING...
Dec 15, 2010 | Onkyo SKW-200 Subwoofer
How to replace damaged subwoofer? Opened cabinet and found that the woofers' voice coil has burnt and the cone can't move. How to replace it the damaged speaker?
Since the coil is attached to to cone, you are looking at replacing the whole 15" driver (speaker)
To get access to the screws that hold it in place, you'll need to remove the front bezel from the cabinet, then remove the screws around the speaker's rim.
For what it's worth, that driver isn't a subwoofer, it's just a 15" driver. JBL does make 15" and 18" subwoofer drivers, but they aren't the same speaker as what's in this EON. Hopefully that will help you when you're shopping for a replacement driver.
Apr 10, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Blown subwoofer fuse..
Well, it should state in the manual what the replacement fuse is.
There might be a fuse holder near the pwr. plug. , Or near the controls for it. If not....
You might have to open up the sub unit ....and find the blown fuse, and remove it to see what you have. Be sure to unplug the unit before opening it up.
Take the fuse to Radio Shack, or your local electronics supplies stores. Replace with the same, or the correct fuse.
Apr 06, 2010 | KLH (AT2100) System
Popping harman kardon subwoofer
Mine did the same thing all of a sudden. The problem is a AC mains detection circuit that seems to affect many previous HK sub models. The solution that worked for me was to replace capacitor C112 on the main pcb of the subwoofer amplifier. You need to remove it from the circuit board with a soldering gun and replace it with a higher rated capacitor. I used a 2u2 40v and the subwoofer is working perfectly again! :)
Dec 23, 2009 | Harman Kardon HKTS 12 System
Infinity home audio system subwoofer does not work.
Fixya is unable to source Infinity replacement parts.
Nov 18, 2017 | Infinity TSS-1100 System
How to open SWA1801Z
Please follow the guide given in the link.. there is a chapter on woofer replacement..
http://www.mackie.com/pdf/repair/SWA1801z%20repair%20guide.pdf
--please give your comments..
have a good day
sree
Jul 01, 2008 | Mackie SWA1801 Subwoofer
No sound from subwoofer
You're in warranty. Appers to be a common problem. Soundstixks should either tell you how to fix it or replace your system.
Mar 03, 2008 | Harman Kardon SoundSticks II Computer...
Yamaha YST-SW205 Subwoofer Logo
79 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
