Supermax F18 password problem
I have supermax F18 set-top-box. It works well but when i want to edit and sort my favourite channels in to the favourites folder, It asks for a password, Where can I get this password
SOURCE: favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Posted on Aug 24, 2007
Nic61
  • 1073 Answers
SOURCE: My Menu is locked and asks for a password which I've forgot?
Is that even possible to sett a password on a swich?
I couldent find anything about that.
Is there a "reset" button back on the swich? if there is push it and hold it for at least 5 seconds, that will remove all possible passwords.
I found the manual for it though,
http://www.startech.com/Data/ProductManuals/SV211K.pdf
Dont know if that helps you, but its the best i can get you.
Posted on Nov 26, 2008
SOURCE: cannot figure out how to set favourite radio stations on my Clok
I just spoke to tech support. They said not being able to set the radio station to 96.1 is a PCA hardware problem. They asked me to get the product exchanged.
Posted on Jan 02, 2009
shishirgarde
  • 114 Answers
SOURCE: how do I get my belkin keyboard to acknowledge the
You must have got a CD with the keyboard. Just insert it and install the software. The keys would work again. If you do not have the CD, let me know the model of the keyboard and I will be able to give you a link to download the software.
Posted on May 13, 2009
  • 341 Answers
SOURCE: Cant change ''favourite'' channels or get ''menu''
Make sure the batteries are fresh in the remote control ( I am assuming you are using a remote control to access the on screen display) If you have a universal remote and replaced the batteries you most likely will have to enter the code for the specific TV that you have.
Posted on Jun 14, 2009
I need a users manual for navmii gps navigation software For Windows
https://www.microsoft.com/en-us/store/p/navmii/9nblggh10k57 = software.
Navmii used to have an old manual at http://www.navmii.net/bin/Navfree_UserGuide_v1.0.1.pdf
The link no longer works.
Here are some basics:
Basic Navfree Help
Navigation is easiest if locations are added to Favourites before navigating. To check a location before adding it to Favourites, or find a location near another location:
Tap Menu icon at bottom right of map screen. Tap Navigate on Main Menu. Tap Address or Google.
Type name to find. Done. Tap down-arrow beside item . Tap Show on map.
Check it is the correct place. If so tap down-arrow and Add to Favourites.
Or drag map to required location. Tap on map. Select Add to Favourites. Change name if required.
To enter a route from A to B, when A is not the current GPS location.
Need to disable GPS in Android Settings - Location.
Easiest if A and B are entered into Favourites. Use Google Search or Address to find names and descriptions, then Add to Favorites.
Then tap Navigate on Main Menu. Tap Favourites and select A.
Tap box with Favorites name in it, and select 'Route from Here'.
Tap Menu icon at bottom right of screen. Tap Navigate. Tap Favourites.
Tap 'Route here'. Tap 'Selected' (not Gps).
Tap 'My Route' to see Route on map.
To clear route: From Main Menu, tap Clear Route.
Cant edit or delete (sometimes) Favourites. Use Jota app . See forums.
Still looking for manual, there blog is very helpful which is the link above.
Helpful links,
https://groups.google.com/a/navmii.com/forum/#!forum/android-app
https://groups.google.com/a/navmii.com/forum/#!topicsearch/user$20manual/android-app/CibF963hA5I
Nov 16, 2016 | Tablets & eReaders
Google search engine
That is Chrome? Lots of people find their settings have been lost. Go to the 3-bar Customize button at top right, click, go down to Settings, click, move down to Appearance, and make sure the box is ticked for Show Favourites. That may do it.
Jun 20, 2014 | Computers & Internet
Audiosonic hdt909
Posssibly antenna orientation could be a factor. Also, STB suppliers recommend repeating channel search periodically so that missing channels magically appear.
Apr 22, 2014 | Televison & Video
Remove favourites
I remove things like that easily, but i also remove all t r o j a n s manually in the registry and hidden and system folders too. Some of this can't be taught quickly in a post. If you install teamviewer i can remotely work on your computer and you can watch and learn. We can talk back and forth with a chat box that comes with teamviewer. If you want this sort of help contact me at mikadot@hotmail.com and we'll have to set up a time where both of us are online for me to fix it. Mike
Nov 03, 2013 | GPS
On my samsung genio touch there is a widget called top 5 friends and i wanted to edit it how do i do this
Go into your phonebook, in the top right hand corner there is a drop down menu, it should say contacts originally, chose favourites and edit your 'favourites'
Sep 20, 2010 | Cell Phones
Want to delete addresses in recently found folder
Click on-Where to-Favourites-All Favourites-Click on the Address you want to delete,click on Edit,it then says Delete,touch Delete,it then asks you if you want to Delete or not,hope this helps you.
Oct 23, 2009 | Garmin nuvi 255W GPS Receiver
Using favourite-tabs will close IE8b
check if you got IE8 Beta latest version.(I'm using Beta 2)
download and install latest version
Export your favourites
Delete all your favourites
Check if issue replicate with empty folder.
Restore your favourites by small batch.
Check if any set of links triggers the problem.
Jan 09, 2009 | Microsoft Internet Explorer 8
Query about listening to radio stations
I created a 'favourites' list of programmes and added the radio channels. Then I could select them in the same way as I did my favourite TV programmes.
Dec 29, 2008 | Televison & Video
Favourite setting lost when switched off
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
