Question about Yamaha YST-SW205 Subwoofer
How you open this subwoofer to replace the speakers?
  • Yamaha Master
  • 15,756 Answers
Wooden? No Screws? Table saw.
Posted on May 13, 2013
MM-6 powered subwoofer. Why can't I open speaker rear panel to replace the internal fuse?
Some speaker manufacturers, in order to make fuse replacement more of a challenge, make it accessible only by removing the speaker (or front panel) and burrowing through the interior to find it.
Apr 05, 2016 | Mirage Audio Players & Recorders
Replace subwoofer
If the speaker enclosure is wood, and there are NO screws, you need to use a table saw to cut the back off.
Apr 30, 2013 | Yamaha YST-SW205 Subwoofer
I burned the speaker on sabbufere! Tell how a speaker can I replace a burned-out! The model of my sabbufera Sony SA-30!
Hello
Your burned subwoofer speaker is [16cm] one, magnetically shelded type. If it ahs burned out, before replacing an other speaker, throughly check if there ahs some short to its output circuit. If there is a short, the speaker you replace will also will burn out within seconds after switch ON the set. speaker have a 6Ohm impedence and rated at 60 Watts. Frequency response is 20 to 150Hz. Whe buying one these specifications must be noted. You can open its back cover after unscrewing the fixing screws. Do it very carefully and peacefully. OK.
Apr 12, 2011 | Sony SA-W305 Subwoofer
Blown
Dont try it yourself! You will definately end up having to replace the whole speaker. Rather try and find someone in your area who does "recoiling" of speakers
May 01, 2010 | Jl Audio 13W7 Car Subwoofer
How to replace damaged subwoofer? Opened cabinet and found that the woofers' voice coil has burnt and the cone can't move. How to replace it the damaged speaker?
Since the coil is attached to to cone, you are looking at replacing the whole 15" driver (speaker)
To get access to the screws that hold it in place, you'll need to remove the front bezel from the cabinet, then remove the screws around the speaker's rim.
For what it's worth, that driver isn't a subwoofer, it's just a 15" driver. JBL does make 15" and 18" subwoofer drivers, but they aren't the same speaker as what's in this EON. Hopefully that will help you when you're shopping for a replacement driver.
Apr 10, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
No sound and I have checked the cable. Is there a reset or a way to check and see if unit is getting power
Subwoofers are hard working speakers, it consumes more power than the satellite speakers, chances are it's easily get busted on high volume. Try to open and check the voice coil for continuity. see if you can repair it or replace
Aug 14, 2009 | Polk Audio PSW10 Subwoofer
I have altec lansing speakers AVS500 and have no sound
It sounds like the subwoofer speaker has blown. If you are comfortable working with a soldering iron and speakers then you can open the case and replace the speaker with a replacement subwoofer speaker. A good online store for replacement speakers is PartsExpress.com
Dec 28, 2008 | Altec Lansing AVS 500 Computer Speakers
How to open SWA1801Z
Please follow the guide given in the link.. there is a chapter on woofer replacement..
http://www.mackie.com/pdf/repair/SWA1801z%20repair%20guide.pdf
--please give your comments..
have a good day
sree
Jul 01, 2008 | Mackie SWA1801 Subwoofer
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
May 12, 2008 | Altec Lansing Multimedia Computer Speakers
Yamaha YST-SW205 Subwoofer Logo
75 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
