Error cartridge jam
Error that paper jam in cartridge area..I've checked all sensors also but no paper even piece of paper is found..please give me the solution.
    Problem Solver:
  • 5 Answers
Hi, as well as asking here, try to ask at likeplum.com under Computers category. There is a bunch of professional helpers. I can GUARANTEE you get a nice answer there.I always get mine there.
source link:
https://www.likeplum.com
Posted on Apr 30, 2013
2 Suggested Answers
  • 43 Answers
SOURCE: JAM IN CARTRIDGE AREA
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3662052&prodTypeId=18972&prodSeriesId=3662052&objectID=c01597539
Posted on Nov 27, 2011
We have found this error is not related to the cartridge area. We found that the exit flag spring in the back of the fuser is wound to loosely. Carefully take the spring while it's in place in turn it one full turn tighter. You will need a hook for this procedure or a bent paperclip. Resecure the end of the spring and bend the tip so it does not unwind. For good measure place a small amount of glue on the end of the spring. Our customer has about 100 of these machines in 10 of those were giving the jam and cartridge area message. After performing this procedure on all 10 we never had another issue with the machine
Nov 27, 2011 | HP LaserJet P2055d Printer
How do I clear paper jam
The flashing error code that indicates a jammed printer is the digital-age equivalent of a flat tire. Sooner or later it happens to everyone, so you'd better know how to get things moving again if you want to finish your print job.
1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2.Turn off the printer.
3.Remove any paper trays. Inspect them for wrinkled or damaged paper.
4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7.If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Sep 21, 2011 | HP Photosmart C5180 All-In-One InkJet...
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
Paper jammed open left cover
Hello, To solve this problem try follow this steps
1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Turn off the printer.
3. Remove any paper trays, inspect them for wrinkled or damage paper.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly
The goal is to keep the paper from tearing. If several pieces are jammed together,try pulling out the middle piece first to loosen the jam.
7. If the paper does tear, try rotating the roller gears manually to free the paper.
8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks
Jun 29, 2011 | Office Equipment & Supplies
The Lexmark x342n all in one printer gives the error code 200.20 i took out the paper jam and tried to print again but it still gives the same fault i also can the drum and tried again but it only...
General tip: If the paper tears when you pull a jam out of the printer, spread the paper out and make sure you have all of the pieces. A small shred left inside can cause another jam.
"I also can the drum" - does this mean you discarded the printer cartridge? I've never seen a cartridge cause a jam. Usually an accordion-fold jam in this area is the result of the fuser rollers not turning or a torn fuser sleeve. A jam without an accordion fold indicates that the paper did not make it into the toner deposition area soon enough - this could be a problem with the pickup roller or the next set of rollers. Worn or dirty rollers can work intermittently before they quit completely.
Also, check the paper detection flag to make sure it isn't hanging up (this is a black plastic tab that sticks into the paper path just before the paper goes under the cartridge, and is pushed up or down by the paper). Look for the U-shaped optical detector that is interrupted by this flag, and make sure it isn't blocked by foreign material.
Jun 22, 2011 | Lexmark X342n All-In-One Laser Printer
Hp laserjet 1200 printer.. i have a paper jam.. i've looked all over to see where i access the roller to get the paper out and i can't find it!
Paper Jammed can be found inside the toner cartridge compartment.
It can also be found in the paper feeder.
It can also be found at the back of the printer (if it can be accessible or can be open).
It can also found in the toner cartridge itself.
Check this areas to find for a paper jammed.
Jun 08, 2011 | HP LaserJet 1220 Printer
MF4350d gives a paper jam error when it has no paper in it.
I hired a technician who came to house and showed me where the paper jam was hidden... found technician on craigslist for $50 flat rate, came out on Saturday. He solved the paper jam problem in 20 minutes. One place to check for paper jam you cannot see until to look behind a hinged plastic flap above the cartridge area. Remove cartridge.Above the cartridge area is a width-wide plastic piece, about 1 to 1 1/2 inch wide from top to bottom, hindged along the top edge, moves but is attached along the two lower corners of the piece by small springs (one at each corner) to the housing of the machine. You cannot easily lift the plastic flap up to look behind it for paper jam until you remove the springs. I used forceps to remove them. Tweezers may work. Don't lose them! Once you remove the springs you can easily lift up the plastic flap (it is hinged) and look behind it into the crevices for any paper. That is where we found a small piece of paper. We needed a skinny forceps to reach into the crevice to get the paper out.
Feb 16, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
At power on I get a 13.20.00 jam inside rear door. Nothing is found in the rear door area. I can't find any flag tied up or a sensor to clean.
This error can be misleading at times. Although it says to check the rear, if you haven't already, remove the toner cartridge and check inside. Also, when you look inside you should see a green lever on the right side. Lift that and check to see if there is paper stuck down there. Another place you can look is in the paper tray area. Remove the paper tray and check to see if there is a piece caught on the way up. Keep in mind when removing a jam make sure you get a whole piece of paper, any missing pieces will cause problems later.
If both areas appear to be clear, think back to if you have a paper jam and got the paper out. Did the paper tear? A small piece could be stuck on a sensor within the printer. If you find paper and everything is good to go, check the pick up rollers to ensure jamming won't happen again. They are located on the paper tray (grey/blue roller) they should like mini tires with grooves, NOT smooth. The other roller is located inside the printer.
Mar 26, 2009 | HP LaserJet 4200 Printer
Paper jam 11
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Nov 07, 2008 | Copystar CS-1815 Printer
35 people viewed this question
jasbo
jasbo
