Question about Xerox Phaser 7760/YDX Laser Printer
Fuser end of life
Fuser is end of life
How to reset xerox 7760 fuser?
Try shorting the chip inside the fuser module. It has three fuses and when its life end, each one blows. Shorting one is 30%more life two is 60% three 99%. One of them is enought
Apr 26, 2017 | Xerox Office Equipment & Supplies
Can't stop beeping
Machine needs something, press machine status button, the one with a question marks. Check "Consumables" for low toner, drum end of life or fuser end of life. Or cleaner or waste bottle.
Mar 19, 2014 | Office Equipment & Supplies
How do I replace Fuser Part RM10865000CN.It is a Roller with some kind of plastic film on it.Not sure how to remove old part.
The fuser part is a fuser assembly. I think you can remove the assembly which is not much difficult. Remove the screws, connectors. You have to remove the tight springsor any other screws holding the metal L plate,. Remove the roller then the fuser. Remove the lockable end cap of the fuser at the other end where there are no heater wires. Remove the fuser film (which you called plastic film). Replace it with new one. Normally it is required to be replaced if it is torn or have holes caused by foreign materials or the life is over. If you are still unable to do it, write me back.
-sonsunny
Jul 18, 2011 | HP LaserJet 3030 All-In-One Printer
Toshiba e studio 250 The print is comming out partially faded. The tona is full, so I am not sure what the problem is, any ideas please? Thanks Anuja
Hi
It might be one of the part life had ended like fuser drum unit life ends or transfer belt unit life ends. Try to check this parts in the LCD screen in LAN setting. or PART LIFE. See if how much percent is their life parts.
Replacing this parts would normal bring your print out to good printing.
Or adjust the contrast setting in the control LCD menu screen to darker setting to make print out more darker.
Jun 22, 2011 | Toshiba E-Studio 250 All-In-One Laser...
Hl 4070cdw fuser life end, how do i reset, i am an angineer
The fuser is reset when replacing the fuser. Just ignore the message until you can't use the machine any more, then replace the fuser.
Oct 06, 2010 | Office Equipment & Supplies
Aculaser 8500 error e525
EPSON AcuLaser C8500 Revision D
Troubleshooting Overview 5-19
1.1.4.4 Service-Call Error Messages
See the following tables for the detailed information on the Service-Call
Error messages.
Engine Related Service-Call Error
*1: Does not appear with this printer because the printer’s life ends earlier.
Table 1-2. Engine Related Service-Call Errors
Error Type
E
Error Code
fff Explanation FIP
E 113 Fuser Unit malfunction (No Fuser Unit) FIP-1.2
E 510 ROS motor malfunction FIP-1.16
E 511 Motor 1 malfunction FIP-1.15
E 512 P/H Motor malfunction FIP-1.14
E 513 NVRAM malfunction FIP-1.13
E 516 Duplex Unit malfunction (Communication) *
E 517 Optional single/double c*ssette malfunction *
E 520 2nd BTR malfunction (Advance) FIP-1.24
E 521 2nd BTR malfunction FIP-1.23
E 523 PCDC malfunction FIP-1.21
E 524 Toner density malfunction (Low density) FIP-1.20
E 525 Toner density malfunction (High density) FIP-1.19
E 526 ADC sensor soiled FIP-1.18
E 527 Deve home position sensor malfunction -
E 530 Environment (humidity)sensor malfunction FIP-1.27
E 531 PR Motor malfunction FIP-1.15
E 532 P/H Motor2 malfunction FIP-1.14
E 533 Thermosensor malfunction FIP-1.25
E 534 Fuser Unit malfunction (Low Temperature) FIP-1.26
E 535 Fuser Unit malfunction (Lamp) FIP-1.26
E 536 Fuser Unit malfunction (Time out) -
E 537 Fuser Unit malfunction (Overheat) FIP-1.25
E 543 Rear fan malfunction FIP-1.30
E 544 Fuser Unit fan2 malfunction -
E 545 Fuser Unit fan1 malfunction FIP-1.28
E 546 Duplex Unit motor malfunction *
E 547 Optional single/double c*ssette unit feeder
motor malfunction *
E 620 K Deve service life FIP-1.31
E 621 C Deve service life FIP-1.31
E 622 M Deve service life FIP-1.31
E 623 Y Deve service life FIP-1.31
E 624 IBT service life FIP-1.31
E 626 2nd BTR service life FIP-1.31
E 627 IBT cleaner service life FIP-1.31
E 830 Optional double c*ssette unit LC3
malfunction *
E 831 Optional single/double c*ssette unit LC2
malfunction *
E 832 MP tray malfunction (lift down) FIP-1.40
E 833 MP tray malfunction (lift up) FIP-1.39
E 998 Engine communication error FIP-1.43
Error Type
E
Error Code
fff Explanation FIP
conclusion :
check the toner if its well plugged. or correctly.
of its leaking or etc.
Feb 19, 2010 | Epson AcuLaser C8500 Printer
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life
Oct 13, 2008 | Xerox Phaser 4500 Printer
Brother MFC 9030
Open the printer and check to see it your fuser is worm up. Do not touch the fuser. If it is cold. you have a problem.
You fuser may be at end of life. Need to be replaced.
cost price of fuser and labor will come close or above cost price of machine. your choice.
Good luck
Jul 24, 2008 | Brother International Plain Paper Fax
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
Xerox Phaser 7760/YDX Laser Printer Logo
56 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
