Question about Alpine Car Audio & Video
Alpine wire code - Alpine Car Audio & Video
Alpine wiring diagram
If you contact Alpine they will be able to tell you if there is an adapter that will plug right into your existing OEM harness. If not then, you'll have to figure out Which wires are which on your OEM harness, here is the Alpine wire code:
Alpine wiring help
HU harness color code pretty much universal.
red=ignition
yellow=battery +
black=ground
blue/white=remote turn on
blue=power antenna
pink/black=audio interupt in (not sure if you have one)
speaker wires
gray=right front
violet=right rear
green=left rear
white=right rear
speaker wire with black stripes is negative.
Sep 29, 2016 | 2011 Dodge Ram Pickup 1500
Wiring digram
Depending on the age of the unit and the vehicle, it should be color coded. So just transfer the wires color for color to the new connector.
Jan 22, 2014 | Alpine Moblie Media Solutions CDE-102
Where to tie in illumination wires and remote lead ,not shown on alpine wire code
An Alpine radio, if equipped with an amplifier turn-on lead, will be blue with a white stripe, and the illumination lead will be orange.
Mar 01, 2011 | Alpine Car Audio & Video
What is the color code for sub woofer control on alpine cda-9856 wiring?
Well I found out on Pages 34 & 35 of the following Alpine manual:
http://vault.alpine-usa.com/products/documents/OM%20CDA-9856.PDF
The Remote / Amplifier Turn On is a Blue/White wire.
May 15, 2010 | Alpine CDA-9856 CD Player
Stereo diagram for 1990 geo prizm
Hello stoogieprezi,
You should have gotten a plug-in harness with your new Alpine. To avoid cutting or tapping the wires on your vehicle, you need to purchase an aftermarket wiring harness. It appears that the Metra 70-1782 is the correct one for the 1990 Prizm.
Then you simply match up the wires on your Alpine harness with the Metra harness. The wiring color code for the harness is shown on the bottom left of the "description" tab and matches up with the Alpine color code on page 18 of your owners manual.
Hope this helps.
Jun 10, 2009 | Alpine CDM-9821 CD Player
Car Audio & Video Logo
47 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
