Question about Yamaha YST-SW205 Subwoofer
Replace speaker how you open the yst-sw205 subwoofer to replace the speakers?
SOURCE: YST-MSW10 quits after about 15 minutes
As far as I can tell, this unit does not have a breaker or anything that would "trip" and be reset by powering off and on. It does have a fuse, which can blow (I replaced mine once) but if the fuse blows, you'll get no power until the fuse is replaced. Spidi, is your computer connected to your subwoofer's line 1 in connection or line 2 in connection? If line 2, that would explain the problem because the auto-off circuit only monitors line 1 in. If there is no signal on the line 1 input, it will power off every 15 minutes. If you are connected via line 1 in, the subwoofer should stay on as long as the volume is fairly loud. That's my problem. At low volume levels, the unit will auto-off even though I'm hearing plenty of bass through the sub. Drives me nuts, but I haven't found a way to disable the auto-off feature. Schematics anyone?
Posted on Nov 07, 2007
SOURCE: yamaha yst m7
i want the drives .......
Posted on Feb 20, 2009
  • 3 Answers
SOURCE: Yamaha YST-MS50 speakers to my i Mac.
You can connect the Yamaha YST MS50 speakers to any audio source that relies on a 3.5mm jack. The YST MS50 should have two audio inputs, so you can use one of them to connect the speakers to your computer. If you don't have a 3.5mm male to male cable, then you can buy that at any electronics store or online.
Posted on May 14, 2009
SOURCE: I need the drivers for Yamaha YST-M15 computer speakers.
The speakers just plug into the sound port on the back of the computer. I never found a need to download any drivers for the YST-M15s that I have. You may not either. Why do you think you need drivers?
Posted on Feb 15, 2010
SOURCE: Yamaha YST-MSW10 subwoofer quits after about 10 minutes
This problem can be solved by either of the following:
1/ Modify the PCBA to prevent the auto shut off feature from working. This is done by adding a 20k ohm resistor across pins 1 & 2 on the timer IC6. This resistor will prevent the timer from turning off the amp. To do this, unplug the amp. Remove the 8 screws on the perimeter of the rear of the amp. Carefully remove the rear plate. Disconnect the speaker wires at the speaker and the front panel connection on the main board. Locate IC6 on the bottom of the main board. Solder a 20k ohm resistor (1/4W) across pins 1 & 2. Pin 1 and Pin 8 are noted on the board. Be sure to insulate the leads of the resistor to prevent contact with the board. See picture. Re-assemble in reverse order.
2/ Some 5.1 channel amps allow independent control of the volume for the subwoofer in their setup. Check your amp to see if you can raise the signal level going to the subwoofer to prevent the amp from shutting off. You can then dial back the volume of the subwoofer using the volume control on the front._436.jpg
Posted on Jan 08, 2011
I obtained a pair of Yamaha YST MS50 speakers with no subwoofer. Can they be adapted to use a different sub, such as the inexpensive Yamaha YST MSW5? The clear problem is in different cabling.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 03, 2016 | Yamaha YST-MS50 Computer Speakers
Replace subwoofer
If the speaker enclosure is wood, and there are NO screws, you need to use a table saw to cut the back off.
Apr 30, 2013 | Yamaha YST-SW205 Subwoofer
No sound from my Yamaha YST-SW315 subwoofer. When I run the test speakers don't have sound either. Not sure if its the subwoofer or the Yamaha RX-V450 receiver
Feed it with an RCA cable any other audio device you may have (CD, TV, MP3 player, PC) to prove it can or can not woof. It will respond to any audio, not just LFE or subwoofer audio.
Apr 14, 2011 | Yamaha YST-SW315 Subwoofer
Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
Jan 10, 2008 | Yamaha YST-SW150 Speaker
sounds like a fuse is getting overheated and tripped or to loud, check your volume settings again.
Jul 29, 2007 | Yamaha YST-MSW10 Computer Speakers
Yamaha YST-SW205 Subwoofer Logo
22 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
