Question about Toshiba Regza 46RV535U 46 in. LCD HDTV
Vertical lines tv 46rv535u - Toshiba Regza 46RV535U 46 in. LCD HDTV
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
My tv screen looks like broken glass but is smooth to the touch
sorry to say its busted, the cost of replacing the lcd will be more than the tv cost.
Dec 16, 2013 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Does Samsung tcon board fit Toshiba TV?
maybe we are smart enough to know better than to be inpolite.
Dec 05, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
46RV535U 46 in. HDTV LCD TV where is the fuse
There are several fuses on the power supply board.
Usually the one that fails is not the main AC line fuse (which is close to the AC line input), but the PFC fuse located, you guessed it, next to the PFC regulator IC on the board.
When the PFC fuse is blown (measuring open) you also need to replace the PFC IC and possibly other components on the board. Most of the time the PFC is sufficient though.
Here's a link for repair service for the board:
http://www.coppelltvrepair.com/p/751/toshiba-46rv535u-power-supply-board-repair-service-for-dead-refusing-to-power-tv-or-faint-display-problem
Also search there for the TV model, we may have repair kits or exchange services available!
Hope this helps!
Jul 30, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Plug in tv hear some clicks but nothing else
If more than one click----main power relay is turning on and then off.
Indicates a problem in main power supply---either the supply or something connected to it is pulling it down.
Suggests problem is on Secondary side of power supply.
Mar 13, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
I have the same problem with a Toshiba RGZA 46RV535U purchased 2/2009. My picture gets darker in the center 1/3rd of the screen intermittently. I have removed and reconnected all cable connections on the...
The tubes are horizontal but require disassembling the cover and the inverter
board completelyfrom the chassis. There were 17 of these flourescent tubes stretching the ful length horizontally. They are so fragile.
Jan 01, 2011 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Toshiba Regza 46RV535U 46 in. LCD HDTV Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
