Question about Garden
John deer f 930 clutch will not stay engaged unless you hold it
    New Friend:
  • 6 Answers
Check the following break switch first, then the seat switch, if that doesn't fix it take apart the main wiring harness under the panel with the ignition switch. Clean the harness well; I used contact cleaner, while it's apart put some dielectric grease on the connections.
If that still doesn't work, follow the wire from the electromagnet that holds the PTO lever in the engaged position, if you check the voltage with a voltmeter it should be 12v (don't remember the amps but it's low). You can also check to see if your electromagnet is bad using a cheap old 9v battery you probably have laying around. With the weak 9v battery it should just hold the lever in position briefly if you're not holding the lever. If not the electromagnet is most likely bad. Worst case scenario is you can wire in a switch to provide power to the electromagnet, but shouldn't need to do that. The connection to the electromagnet is
"Weather Pack Environmentally Sealed Connectors" made by Delphi Packard. There are several places you can get the connectors including amazon if you would prefer not to modify the factory connections.
Posted on Jul 30, 2013
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
Pto switch will not stay engaged on my john deere 265 model lawn tractor
Poor connection, bad switch or faulty clutch coil. Check for constant power to clutch wth test light, if light goes out at same time check wires to switch for corrosion. If you can find the 12v supply to the switch check it the same way. If it has constant power to clutch check for good ground, if that is OK replace clutch. If power stops when clutch does replace switch or in switch. There are prob some safety switches at seat and possible on reverse these can cause switch to shut off clutch also. Check these for good connections. If possible check these with continuity tester when all wires are removed while exercisin switch.
Apr 04, 2018 | John Deere Garden
John Deere 1020 gas won't stay started unless you hold the key on to keep the starter engaged
That means it's not starting. It's just turning over...
First thing to do is check for spark. If you have spark then its a fuel delivery problem. Most likely the carb needle and seat needs to be replaced.
Oct 18, 2017 | John Deere Garden
Zero turn John Deere won't run unless blade is engaged
check clutch adjustment or belt tensioner
May 02, 2017 | John Deere Garden
How to replace pto clutch on John Deere x320
Removal and replacement fairly straight forward, you just need to prevent the engine crankshaft from turning. This can done either holding the flywheel or using a piston stop. Also some clutches have a set of flats that a 1-3/8 open end wrench will fit.
When reinstalling the center bolt torque to 50-55 ft-lbs. Also make sure the anti-rotation device is engage into clutch assembly or it will rip the wires out at the first startup.
Apr 07, 2015 | John Deere Garden
John Deere L120 wiring diagram
The electric clutch draws current while engaged. It is quite hungry on power which means that if the battery is low, the generator may not be making enough to charge the battery and hold the clutch in too. This is why the batteries on these machines are so large relative to say an ATV battery. I have several times experienced units with low batteries which started the engine OK but would not hold the clutch in. The battery may be getting old and not holding the charge. Try charging with a mains operated charger. Make sure to check water level in battery cells. Running them dry can ruin the battery.
Aug 01, 2014 | John Deere L100 Series
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
I have a john deere K series 17hp riding mower. when I try to engage the blade the safety mechanism works but the blade will not engage. the switch has been replaced.
Hi, sounds like the clutch. If you feel confident you can strip the mechanism down, clean and replace, otherwise its a new clutch.
Aug 29, 2010 | John Deere Garden
John Deere 318 blades won't engage once it gets hot.
Check the clutch gap in the front of the machine (the one that engages the belt) by tightening or loosening three lock nuts around clutch. Tightening decreases gap/ loosening increases gap. Note: do not tighten too far as it will result in clutch drag or lockup! Stop when its just starting to touch then back off slightly. Also without a proper charge on the battery the magnetic power for the clutch is altered and not strong enough to engage clutch when hot. Find out why battery light is on.
May 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 997 z trak pto not working,changed pto switch not help
You may have a defective park brake switch or the pto clutch could need to be adjusted.Does the machine **** down when you try to engage the pto?If so also check the seat switch.To adjust the pto clutch you need a 9/16' wrench and tur all three lock nuts on the clutch a half turn at a time a retry the clutch,keep going until it will stay engaged.
Nov 08, 2009 | Garden
Garden Logo
429 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
