Question about Samsung Computers & Internet
Low format please tell me how to do a low level format on my samsung 2tb external harddrive with usb 2. I recovered the files but I'm having trouble with the drive even after scanning and fixing and doing the normal format, please help
  • Samsung Master
  • 2,072 Answers
You probably have a messed up partition table. You can download the hiren boot cd and use the linux rescue environment. Once loaded use Gparted to create a new partition table and format the drive. If that doesn't work there is a low level format tool under the first menu on the hiren disc
Posted on May 03, 2013
  • 75 Answers
SOURCE: help to fix WD external hard drive
Try and use hirens boot cd to breath new life into the drive. It may just need to be repartitioned and reformatted to resolve the problem. Hirens can be found through a google search and it's a free download. All you need to do is burn it to disk. Then enter your bios and make sure that you can boot from your cd/dvd drive. After that move through the hard drive tools and see what you can find wrong with it. More often then not you'll find the problem using this fine boot disk. However, if it doesn't work then there is one other possible method.
Download this from western digitals website.
http://support.wdc.com/download/index.asp?swid=1
it's a last resort method to trying to revive a hard drive. Sometimes it works. Most of the time the drive is dead and gone.
Good Luck!
Posted on Jan 02, 2008
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
  • 115 Answers
SOURCE: hi i have a WD3200 external hard drive. i had lots
you should use system utility
open my computer right click on your drive then properties-tools-chack now
or go to any expert to recover data
Posted on Nov 08, 2009
SOURCE: my iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Posted on May 23, 2010
  • 14 Answers
SOURCE: Seagate external 2.0 USB 60GB harddrive
Well, in your case your external may corrupt. The solution is format the drive and then try some so-called data recovery software. After finishing the format option. Do it as follows.
Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
Posted on Jan 13, 2011
I have a problem with my external harddrive. when plugged in it takes too long too read and when I transfer files from or too the harddrive it takes up to one day. sometimes the files is not even as b
Are you plugging directly into the computer or using a USB Hub. Cheaper USB hubs have awful data throughput. I have one that I tried to plug a sd card reader into and it would take ten minutes for a 60 megabyte file. Connect directly to a port. Or download Samsung diagnostics and make sure that the drive is in proper working order. Verifying The Hard Disk Drive Is Working Normally
Jan 10, 2015 | Samsung G2 Portable External HX-MU064DC/...
Toshiba DWC120 2TB Harddrive not recognised
Before connecting anything to an USB port you need to install the software for the device. Then you can connect it.
But when you have an old laptop it could be it can't handle the 2 TB.
First install the software that came with the drive. Then see if the laptop can handle the 2TB.
Dec 20, 2013 | Toshiba 2TB Desktop External HDD Hard...
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
Samsung Story Station 2TB External HD has lost all my files ?!?
You need to get the disk to a data recovery expert. anything else might make it worse.
Nov 14, 2017 | Samsung STORy Station 30 2TB USB 30 Dark...
Iomega 2TB Prestige External Hard Drive NOT COPYING FILES
A shot in the dark but partition it as two 1tb drives.
Sep 02, 2017 | Iomega 2TB Prestige Desktop HDD USB
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My WD Elements hard drive stopped working suddenly and now I can't have access to it. I don't wanna go through the process of getting a data recovery software and spending hours trying to get a few...
1. Try to use a different USB Cable and test. 2. Open the external harddrive and replace the disk with a spare one or working one. Then test if it connects. a. If it does not connect then the problem is the electronic board of the external harddrive. Buy a Harddrive enclosure so as you could still use and retrieve your valuable data. Or slave the drive on your desktop computer and see if its connect. b. If it connects then you have a faulty harddrive. I hope you have a backup of what you have there.
Jul 20, 2011 | Western Digital 250GB ELEMENTS EXTERNAL...
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
I have the ts16GB JFV60 transcend usb jet flash. I cannot write or save any files on it. Files are recovered. When tried to format it registered write protect.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format uxb jet flash
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jul 01, 2009 | Transcend (589307) Media
Computers & Internet Logo
94 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
