Question about 2004 Audi TT - Coupe, with antenna, with spoiler - Sunbrella Extreme Sun Car Cover
Audi tt headlight
Lo lite right side comes on sometimes sometimes not. Replaced bulb, sme result. Once the light comes on it syaysmon
  • 3 Answers
Replacing the bulb wont make any difference since it is not fused. You need to check the connections and wiring harness of the headlamp assembly and confirm that no wiring is loose. You may take the help of http://www.automotix.net/autorepair/diy/2004-audi-tt-repair.html which will enable you to work on the car with ease.
Posted on Apr 30, 2013
My right side headlight not working on A4, 2007. Install new H7 bulb from Audi but it did not work. I install the right bulb into the drivers side and it work. I suspect an electrical problem. Possible no...
if it is a hid light system they are famous for the balast going bad. follow the wires from light bulb. if they go into a box then its a hid system and it is the balast box that needs to be replaced. also check the fuses, sometimes there are seperate fuses for each headlight.
Mar 09, 2013 | Cars & Trucks
Can't adjust the height of the headlights
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Sep 13, 2009 | 2004 Audi TT
Audi TT Intermittent headlight
Did exactly as you said, replaced both bulbs with the d2s as you said and got them on ebay, driver side was clearly more difficult to put in, passenger side very easy, worked perfect for 1 day and the intermittent problem returned. What to do.
Aug 22, 2009 | 2005 Audi TT
Same issue
I'm having the same problem wiht my 2004 TT. Luck for me, the problem followed the bulb. I can't answer the question about the ignitor, though replacing it seems to be your fix. The ignitor ain't cheap, but the cheapest place I've found is www.1stvwparts.com. Good luck.
Jul 14, 2009 | 2005 Audi TT
Audit TT passenger headlight goes out
The ignitor or ballast must stay energized for the bulb to stay lit..If the bulb comes on then goes off, or flickers, then the ignitor is defective. You are in the early stages of failure, it will eventually stop working altogether
Jun 27, 2009 | 2005 Audi TT
Audi tt quattro turn light is not Blinking-stays on
The signal flasher is within the emergency flasher. It will usually make a lot of clicking noise when faulty though. Check all the bulbs on the car for proper operation. Good luck!
May 26, 2009 | 2001 Audi TT
Audi TT HID bulb needs replacing
You can change the bulb easily yourself in about five minutes, especially on the passenger side. You may want to disconnect the battery, though I don't know if that is necessary. You may also want to handle the bulbs wearing latex or nitrile gloves so as to not get your skin oil on the glass.
1. Remove the decorative cover that conceals the Coolant reservior. There is a single philips screw near the firewall that holds the cover down.
2. Find the back of the headlight and pull the metal wire clip that holds the back of the headlight cover toward the engine. Remove the cover.
3. Look inside and find the back of the HID bulb--it will be toward the outside fender. Twist the connector until it separates.
4. There is a retainer ring that holds the bulb in. Again, twist that until it comes loose. The bulb should come right out.
5, Put the new bulb in, noticing the notch is on top. Also, attach the retainer ring. It is marked "Top" to help orient it. Reattach the connector with a twist.
6. Make sure everything is firmly in place. Reconnect your battery and test the lights. Finish putting anything else back on.
Good luck.
Mar 14, 2009 | 2005 Audi TT
Audi A4 "left dipped headlight" problem
AUDI A4- 2005. There is a technical service bulletin for this exact problem. take it to the dealer when this issue has happened while driving. During a daytime drive when cold see if you cant get the light to fail while circling your dealer. As soon as you pull into the service drive do not turn the car off do not flip the switch. I am an Audi Technician for a dealer in Birmingham alabama. Personally this is not my favorite repair to perform; What audi states is that if the bulb flickers the bulb should be replaced; if one side fails the bulb should be swapped left to right if the fault continues with the bulb the bulb is at fault; if the bulb is swapped and the bulb fails again on the same side it is the module. NOW: I currently am working on a 05 A4 that both bulbs both modules have been replaced and Audi has no clue what to advise on a repair. THIS IS AN ISSUE if it has happened to you ask if there is a TSB for this issue or try to find it for yourself.
Dec 09, 2008 | 2005 Audi A4
2002 Audi TT
Nothing special at all - just remove the back cover on the headlamp and you'll see inside that the bulbs are pinned in place with hinged metal wire clips. Release the clips and the bulbs should come right out.
Sep 15, 2008 | 2002 Audi TT
2004 Audi TT - Coupe, with antenna, with spoiler - Sunbrella Extreme Sun Car Cover Logo
133 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
