Question about Yard Machines 11A-020B000 20-Inch 148cc Briggs Stratton 300 Series M
Free Manuals Briggs Stratton
Throttle springs and cables
2 Suggested Answers
  • 149 Answers
SOURCE: New mower 158cc Briggs & Stratton engine April 2010
Um if its new take it back before you damage the govenor then its not warrenty!!
the springs are fine. the metal the the spring conects to on the throtle control sets the high speed. dont play with unless you know what your doing for every ones safety
Posted on Jul 02, 2010
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
My lawnking Briggs and Stratton engine won't start
check you put it back together correctly including the cable and springs on throttle
Aug 04, 2014 | Briggs & Stratton Garden
How do I adjust a throttle on a briggs and stratton engine?
If it the simple handle type throttle cable..push it to full tbottle and follow the cable to the carb..you should fund a small clamp that hold the cable in position..jus loosen and adjust the carb throttle to full throttle and tighten..then push it back to idle to make sure it Idles if not adjust the clamp again until you reach both throttle and idle..good luck..
May 17, 2014 | Briggs & Stratton Briggs Stratton...
Engine runs wide open all the time
linkage stuck
throttle cable broke
something like spring unhooked
inspect
free up and lube
Aug 12, 2013 | Briggs & Stratton Garden
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Think i have a problem with governor on my 21hp v-twin briggs. it jumped to max speed and can't get it to slow down. which part of the governoring system could have let go?
Check for a broken spring on the governor linkage, follow your throttle control cable down to where it attaches to the throttle mechanism. In behind where the cable attaches you should be able to see a spring on the governor arm, the spring may have broken or somehow came out of its attaching point. Obviously be very careful about over-revving the engine, it could result in a broken connecting rod and a hole in the side of your crankcase.
Aug 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Spring hook-ups throttle free design carb.
Spring goes from throttle air valve to plastic lever under flywheel. Cooling fan on flywheel provides pressure to open/close throttle. As engine (fan) speeds up, pressure on lever causes throttle to close. As engine slows, throttle will open. System achieves an equilibrium very quickly.
hope it helps!
May 30, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Yard Machines 11A-020B000 20-Inch 148cc Briggs Stratton 300 Series M Logo
604 people viewed this question
Top Yard Machines Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
rjivaro
donald boissonneault
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
