Question about Aiwa NSX-A505 CD Shelf System
SHARP cd stereo model CMS-R350AV
The player will pick up the cd and immediately drop it down and move to the next space and does the same thing for all 5 slots. Have tried to use a cd cleaner but it picks it up and drops it right away.
  • brangbilly Mar 03, 2008
    I have the same problem plus dial does not light up or show station or band info. Tried the reset switch. No help
  • 91 Answers
Your cd player is probably at random and if there is no disc in the cdplayer it would automatically go to the next one
Posted on Aug 08, 2007
SOURCE:
Jukebox will turn on and pick up cd but won't play
You did not say if the disc turns or not. You also did not say if it puts the disc down and immediately picks it up. If it immediately picks it back up you probably have a bad microswitch. Other than that the first thing to do is to clean the laser eye. Use 90% or higher isopropyl alcohol on a q-tip. DO NOT USE 70% ISOPROPYL. It has too much glycerin and mucks up the eye. Many people screw up their boxes this way and it is a simple fix. Hope this helps.
May 03, 2014 | Wurlitzer Jukebox CD Player
I have a Wurlitzer CD jukebox. The arm picks up a CD and immediately returns it to the rack then repeats.
The arm is not closing a switch or a switch is stuck closed in the mech area. You will probably need to clean all moving parts with alcohol because chances are, the old oil or grease has become sticky and things are not moving correctly, especially if you notice the arm moving slower than it should. Check all switches and use a little alcohol on them too.
Feb 20, 2013 | Wurlitzer Jukebox CD Player
I would like the instuctions to a "Dr Who" boad game made by Toy Brokers. This is the one with a battery powered, revolving "electronic" board. Can you help?
Hello, hope this one can help you out...
Object of the Game:
After the latest battle with the Daleks, the TARDIS is malfunctioning badly and needs vital repair. Race through space and time collecting each of the following 6 TARDIS Repair Component Cards which are needed to mend your faithful time travelling machine.
  1. Communication Array - located in present day London
  2. Wormhole Generator - located 200,000 years in the future on Satellite 5
  3. Temporal Destination Input Device - located 5 billion years in the future on Platform 1
  4. Geographical and Interstellar Destination Input Device - located in Victorian Cardiff
  5. Internal Power Regulator - located in the year 2012 in an Underground Bunker in Utah
  6. External Integrity Stabiliser - located in WWII London during the Blitz
But beware, the Daleks are also roaming through space and are still looking for you. You must avoid them at all costs if you are to be successful in your quest.
How To Play:
The youngest player starts by spinning the spinner and moves their playing piece in any direction, but one direction only equal to the number marked on the outer dial of the spinner. But before you move, you will notice that the spinner also has an inner ring. This is used to move the Daleks. The Daleks can also move in any direction and are moved by the player on your right. Only one Dalek is moved in any one turn, and is moved before you move your Doctor.
Note: The Daleks do not move in the first round of turns.
Once this has all happened and any actions that are required have been completed (see the "On Your Journey" section later), play then moves to the next player in a clockwise direction. Again the player on his/her right controls the Dalek for that move.
On Your Journey:
As you journey round the board you will land on the following squares:
  • (Purple Swirly) Time Portal - landing on this space allows you to travel directly to any other similar portal space on the board during that move. Once you arrive at your new destination, play moves to the next player. Beware, Daleks can also move through the portals so they may catch you unawares!!
  • (TARDIS) TARDIS Repair Time Zone - landing on this space allows you to take the TARDIS Repair Component Card associated with that coloured Time Zone. Keep these face down to make it harder for other players to know which ones you have. Continue your journey to collect all 6 that you need to repair the TARDIS. Note: Once all the TARDIS Repair Component Cards belonging to any one Time Zone have been taken, the only way to get one that you require is at a Trading Space Port or if you are the player controlling a Dalek which lands on another player.
  • (Space Station flying out of square) Trading Space Port - when you land on this square you must immediately travel to the Space Port orbiting that Time Zone. Once there you must trade TARDIS Repair Cards with any other player of your choosing. To initiate a trade, announce which player you wish to trade with and then each player spins the spinner. The one with the highest number on the outer dial can take any TARDIS repair component Card from the loser. As each player keeps their cards face down, you will have to use your memory (or any extra sensory powers you may have) to work out which card would be useful to you. Note: you must have at least one TARDIS Repair Component Card to be allowed to initiate a trade at a Space Port. After trading, return your playing piece to the outer ring ready to continue on your next turn.
  • (Yellow/Orange shapes) Mystery Planets - when landing on one of these spaces, push and release the flashing blue light on top of the TARDIS. This will initiate a random sound effect which signifies different actions that you will then have to perform. See the Sound Effect Chart at the end. Beware as these mystery planets could also hide actions for the Daleks. Note: If you need to repeat the last sound effect, simply push and hold the flashing light for 3 seconds.
  • Black Hole - At certain points in the game you may be caught in the grip of a Black Hole. You must move your playing piece to this section of the board immediately and must stay for 2 turns or until you spin a 6 on what would be your turn. Once you are released from the Black Hole, you must journey back to your home Time Zone square.
Note: The Daleks are still moved by the player on your right when you are in the Black Hole.
Moving the Doctors and Daleks:
  • If on your journey you land on the same square as another Doctor, move to the next available empty space.
  • If on your journey you land on the same space as a Dalek, the player to your right can take any one of your TARDIS Repair Component Cards and return it to its Time Zone and the Dalek is moved to any available Dalek home asteroid.
  • If on your journey a Dalek catches you, the player on your right can take and keep any one of your TARDIS Repair Component Cards (if you have one) and you immediately move to your home Time Zone square.
Sep 16, 2010 | Toys
Need the lastest firmware update file for a Sharp BDHP21U Blu-ray Disc Player. Can you help me?
Go to the following web page:
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
On the left hand side of the page you will see a heading called: "FIND PRODUCT DOWNLOADS BY PRODUCT MODEL #". You will select "Blu-ray Disc players" in the first line. The second drop down does not have your model number included so choose "Model Not Listed". Then in the next line down enter your model number "BD-HP21U" and leave the last box as "ANY". Then press the Search button. The system will give you the one firmware update file that is available. You will then download that file.
The player came with a CD with software to install on your computer. Connect your player to your computer with the supplied cable and run the software to update your firmware. The program should then automatically detect the player, ask you where the update file is , and then automatically load that update to the player. Be very careful to ensure that you do not interrupt the update process. You could cause the player to lock-up and then have to go through a lot of grief to get things back to normal.
Apr 18, 2010 | Sharp AQUOS Blu-ray Disc Player
Sharp CMS C640 CD player not working right
You can get a brand name lens cleaner for CD players from your local electrical shop etc. If it is dirt on the lens, that should cure it.
Feb 10, 2010 | Sharp CMS-C640 Shelf System
Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Nov 27, 2009 | Audio Players & Recorders
Drink spill killed stereo
As long as it is still powering up, it can be removed, taken to a eletrical repair shop, and cleaned. Sounds like the internal drive or gearing got gummed up.
It just needs a good cleaning.
Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | Saab 9 5 Cars & Trucks
CD's won't play on AIWA Compact Disc Stereo System
I have a Aiwa Compact 3 Disc Stereo Systen that will pick up the 1st CD, spin it for about 5 seconds, lower it and then go to 2, same thing, on to 3 and same thing. Please help.
Oct 30, 2008 | Audio Players & Recorders
My ancient Sharp CD - BA150 bookshelf stereo 3-disc CD player has suddenly stopped working. Even with 3 discs in tray, player won't recognize they're there and reads" NO DISCS" on LCD display....
I have repaired a lot of these exact Sharp stereo's and can say with certainty that you have a bad laser pick-up. The only cure for your problem is to have the pick-up replaced. It says no disc because that part is bad and can not read the disc, so it thinks there is no disc.
A repair for this would cost in the area of $125 to $150 depending on the rates of the service center you take it to.
This should give you the information you need to determain if it is worth fixing to you.
Sorry it is not something you could fix easy, but that is just the nature of these types of stereo's. That part, the laser pick-up, is a very expensive part. I have no idea why they charge so much for it, but it is killing the repair centers making so many of these too costly to fix.
I hope this helps, let me know if you require any further help.
Dave
Aug 27, 2008 | Sharp Audio Players & Recorders
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Aiwa NSX-A505 CD Shelf System Logo
139 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
