Can't access to my router
I can't access to router sitting
  • 7,627 Answers
It would be helpful if we knew the Make, Model of device. Or , using the Make, Model, google the manufacturer for a User Manual.
Posted on May 02, 2013
WIFI router loses security settings after reboot & continual restart AP required
As far as I know, access points support Wi-Fi wireless communication standards through i have encountered such kind of problems like you. Maybe you can reset the Access Point from the very beginning, hope it will be done... And if you think it's necessary to know WIFI and Access Point better, there is an article for you" http://goodrouterswitch.blogspot.com/2012/08/what-is-access-point-and-how-to.html"
Aug 02, 2012 | NetComm NB5PLUS4W Wireless Router
Wii Access point
If you have a wireless router you just connect to that
Jul 07, 2012 | Nintendo Wii Console
Dlink dsm 330 keeps losing contact with pc
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Mar 03, 2012 | Computers & Internet
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
How to change password?
If you can't remember your Network Password, you need to reset your router in order to change your network password. Here's how to do it;
1. With the router still on, find a small hole in the middle right (router's back is facing you) of the router, near the power chord with label 'reset' below it. Using a thin and hard object like toothpick or wire, press the unseen button inside the hole and hold it for at least 15 seconds.
2. Using a computer connected to the router, log-in to Router's IP which 192.168.0.1.
3. In the log-in page, type 'admin' as username and in most DIR 600 routers, password is usually left blank. If blank password fails, use 'admin' as password.
4. When you get into the Router's page, look for the option "Wireless Setup" and start configuring your wireless access. You may have two (2) options to configure your wireless. The first is by using a wizard, and the second is by manually configuring it. Find your comfort there...
Hope this helps...
Jun 03, 2011 | D-Link DIR-600 Router
How do I access my router? I type in http://10.0.0.1 and all I get is search results not the router itself. I have been able to do this in the past. Thanks
I understand that you are unable to access the configuration page of the router WGR614. Please perform the below task on your computer connected to the router:
A. Click on Start then go to Programs and go to Accessories and open Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and press 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Please try to access the configuration page of the router using the address that you got in the 'Default Gateway'.
Hope this allows you to resolve the issue. Please revert back for any further clarification.
Regards
Anand
May 14, 2011 | NetGear WGR614 Wireless Router
All of a sudden, I can't connect to the internet. My network connection is asking for a security key. I have never had to do that before & I have no idea what it is. Please help.
Someone nearby may have created a new wifi network, and your computer is trying to gain access to it. The first thing to do is to verify that you are indeed trying to connect to your own wifi network by checking the SSID of the network. Or, you can physically move closer to your wifi router and see if you can then connect as expected.
If you're still having trouble after that - you'll need to access your router's setup pages via a computer that has a network cable connected between it and one of the LAN ports on the router. Login as usual with your username & password credentials and then change the SSID, encryption and the username & password information. If you are unable to login, then it is very possible that the person(s) that took over your wifi have also attempted to lock you out of it. You'll have to consult your router's manual to learn how to perform a hardware based factory reset. Once this has been done, you'll need to set up your variables for your network again. Make sure you secure the wifi to prevent unauthorized access again. This mean using WPA instead of the comparably very weak WEP security AND then locking down access to the setup page with a new username and password.
I hope this helps and good luck. Please rate my reply. Thanks.
Apr 15, 2011 | Computers & Internet
Connecting to Microsoft Outlook
Please check with the firewall sitting of our os and router it may conflict disable the firewall sitting in windows from control panel
think this may help u
Feb 04, 2008 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
David Payne
David Payne
