Question about ZEEPAD New 7 inch Epad with android 2.2 tablet pc includes WiFi 720p Video
Prepare enter mmc update mode
Screen on but not work
How to reset SC544 for Ricoh MPC 3000 when the keyboard is faulty
Maybe TOUCH panel doesn't work.
Try to calibrate it:
Yellow -->1-->9-->9-->3--> Press Stop(red one) 5 times.
1 - Touch screen adjustment!!! Follow instructions on the screen.
After calibrating exit and try again to enter service mode.
Good luck
Prepare to by new TOUCH Panel
Pifonski
Sep 30, 2015 | Ricoh Aficio Office Equipment & Supplies
Acer stuck on preparing to stand by
I would force power off, (press and hold down the power button) then start up windows and download any updates that are missing and then use the Shut Down command instead of the Stand By/Sleep mode.
Sep 11, 2014 | Computers & Internet
Sir, when i run my Nokia 3110c music player than my mobile displayed " no music file found" so why? please give me solution my problem.
Firstly check the mmc you have inserted if it is more than 1gb this handset cannot load the files from mmc because the free memory of this handset is small.If mmc is smaller than 1 gb check phone memory status partcular the GALLERY,MESSAGES,CONTACTS......after removing all useless thing restore it by using short cut *#7780#....enter code 12345 or what you have made.Try this step it will surely help you However it is still not working.Contact mobile repairing shop to flash/update firmware your phone.thanks.......
Sep 23, 2010 | Nokia 3110 Cellular Phone
How to unlock my mmc?
Try the default manufacturer password
It is 1234
Feb 23, 2010 | Motorola Mobility RAZR V3
My Nokia N73 is very slow these day's,After an updating.Solution?
Format the software & install it again. Some chance of virus.
Feb 19, 2010 | Nokia N73 Music Edition Smartphone
How to change silent mode to normal mode, the phone line it's fine, I just can't hear the incoming calls
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset2_bing.gif)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
Dec 15, 2009 | Samsung Prostar 816 Phone
How do i change the time on my samsung prostar 816 phone?
  1. Enable technician programming mode
    • Press "#" - "PROGRAMMING" is displayed
    • Dial "20" - "MMC ENABLED" or "MMC DISABLED" is displayed
    • Dial the password (default - 1234) - if wrong password is enter "ERROR" is displayed
    • Dial "1" to enter program mode
    • Press "#"
  2. Press "#" key - "PROGRAMMING" is displayed
  3. Dial "55" - the display shows "YY MM DD W HH MM" and then the current date is displayed
  4. Enter the new date
    • YY = Last two digits of the year
    • MM = Month (01 - 12)
    • DD = Day of the month (01 - 31)
    • W = Day of the week (1 -7 day of the week begins on Monday & ends on Sunday)
    • HH = Hour (Use 24 hour clock)
    • MM = Minutes (0-59)
  5. Press "#" - new date is saved
Jul 24, 2009 | Samsung Prostar 816 Phone
Screen black
Are any USB device connected to it? If so, disconnect them.
Try to start now, if this does not work:
When the system boots up, try hitting the F8 Key and see if you get a Windows menu? If so, try and start in Safe Mode. If this works, you have a hardware failure and you will not need to look for the problem. First place to start is reboot and F8 again and this time go in VGA mode. If this works, Run Windows update and this should replace any drivers that are not good, including video. If you cannot get in VGA mode, you know your problem, the video adapter or drivers. Remove them in Safe mode and run Windows Update.
If you need any additional assistance just click "ASL ME"
Please remember to rate this solution
Sep 25, 2008 | Toshiba Satellite A135-S4527 Notebook
MMC memory card does not work
It might just be the type of card. I put a SD card in mine and it works fine.
Dec 11, 2007 | Rio Forge Sport Digital Media Player
ZEEPAD New 7 inch Epad with android 2.2 tablet pc includes WiFi 720p Video Logo
297 people viewed this question
Top ZEEPAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ZEEPAD Audio Player and Recorder Expert? Answer questions, earn points and help others
