Assembly instructions how to assemble connector
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Washing Mach... Master
  • 102,366 Answers
Connector for what?
Posted on Apr 30, 2013
How to change multifunction switch on 04 buick century
STEP BY STEP INSTRUCTION First, any time you work around the steeringcolumn you it is a must to disable the air bag system you will do this my disconnectingthe battery. After you disconnect the battery wait at least 5 minutes before proceeding. 1. Ifyou have tilt remove the tilt actuator arm by firmly pulling straight out. 2. Removethe upper and lower trim covers. 3. Removethe wire harness assembly from the wire harness strap. 4. Disconnect the turn signal andmultifunction switch assembly connector from the SIR system coil connector.This is alongside the steering column there is an 8mm bolt in the center of theconnector that must be removed to disconnect the connector halves. 5. Slide the 2 connectors of the turnsignal and multifunction switch assembly out of the bulkhead connector. With a smallscrewdriver slightly pry between the connectors to release them. 6. Removethe 2 pan head tapping screws and from the turn signal and multifunction switchassembly. 7. Removethe turn signal and multifunction switch assembly from the steering column tilthead assembly. INSTALLATION PROCEDURE 1. Installthe turn signal and multifunction switch assembly onto the steering column tilthead assembly. 2. Screwthe 2 pan head tapping screws and into the turn signal and multifunctionassembly.3. Slidethe 2 connectors of the turn signal and multifunction switch assembly into thebulkhead connector. 4. Connectthe turn signal and multifunction switch assembly connector to the SIR coilconnector. 5. Installthe wire harness assembly (1) into the wire harness strap (2). 6. Installthe upper and lower trim covers. 7. Installtilt actuator arm. 8. Reconnectthe battery.
Mar 01, 2011 | Buick Century Cars & Trucks
Need help changing out the low beam on drivers side of 2006 buick rainier
Removal & Installation
Bulb Replacement
To Remove:
CAUTION
Halogen bulbs contain pressurized gas.
Mishandling a bulb may result in the bulb shattering into flying glass
fragments.
CAUTION
Make sure to wear eye protection when
handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb,
only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into
contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb
properly.
CAUTION
Do not allow children to handle halogen
bulbs.
  1. Turn the lamp switch to the off position.
  2. Make sure the bulb is cool before changing.
  3. Remove the headlamp assembly from the headlamp panel.
  4. Remove the rear access cover from the headlamp assembly.
  5. Disconnect the headlamp connector.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket
    counterclockwise.
To Install:
  1. Connect the headlamp connector.
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket
    clockwise.
  3. Install the rear access cover onto the headlamp assembly.
  4. Install the headlamp assembly into the headlamp panel.
Headlamp Assembly
Chevrolet
To Remove:
Headlamp Assembly (Chevrolet)
  1. Remove the grille from the front of the vehicle.
  2. Release the headlamp assembly retaining tabs.
  3. If equipped, disconnect the headlamp leveling motor connector.
  4. Disconnect the headlamp connector.
  5. Remove the park/turn and side marker bulb sockets from the headlamp
    assembly.
  6. Remove the headlamp assembly from the headlamp panel.
To Install:
  1. Place the headlamp assembly into the headlamp panel.
  2. Install the park/turn and side marker bulb sockets into the headlamp
    assembly.
  3. Connect the headlamp connector.
  4. If equipped, connect the headlamp leveling motor connector.
  5. Lock the headlamp assembly retaining tabs.
  6. Install the grille onto the front of the vehicle.
GMC, Oldsmobile, Buick, Isuzu, and Saab
To Remove:
Headlamp Assembly (GMC, Saab, Oldsmobile, and Buick)
  1. Release the headlamp assembly retaining tabs.
  2. Disconnect the headlamp connector.
  3. Remove the park/turn bulb socket from the headlamp assembly.
  4. For GMC, Saab, Oldsmobile, and Isuzu vehicles, remove the side marker bulb
  5. Remove the headlamp assembly from the headlamp panel.
To Install:
  2. For GMC, Saab, Oldsmobile, and Isuzu vehicles, install the side marker bulb
    socket into the headlamp assembly.
  3. Install the park/turn bulb socket into the headlamp assembly.
  4. Connect the headlamp connector.
Oct 28, 2010 | 2006 Buick Rainier
How to change headlight in 2005 trailblazer
Its Pretty easy see instructions below
REMOVAL PROCEDURE
  1. Open and support the hood.
  2. Remove the grille.
  3. Pull up on the retaining tabs (1) in order to remove the headlamp assembly from the headlamp panel.
  4. Disconnect the headlamp leveling electrical connector from the motor/actuator if equipped.
  5. Disconnect the headlamp electrical connector (2) from the headlamp assembly.
  6. Remove the side marker socket (4) from the headlamp assembly.
  7. Remove the park/turn socket (3) from the headlamp assembly.
  8. Remove the headlamp assembly from the headlamp panel.
  1. Position the headlamp assembly to the headlamp panel.
  2. Index and seat the tabs on the park/turn socket (3) to the headlamp assembly.
  3. Index and seat the tabs on the side marker socket (4) to the headlamp assembly.
  4. Connect the headlamp electrical connector (2).
  5. Connect the headlamp leveling electrical connector to the motor/actuator if equipped.
  6. Align and install the 4 locator pins on the back of the headlamp assembly into the retaining tab holes.
  7. Push down on the retaining tabs (1) in order to lock the headlamp assembly into the headlamp panel.
  8. Install the grille
Oct 20, 2010 | 2005 Chevrolet TrailBlazer
How do I Remove Headlight Assembly on my 1998 Eclipse and is there anyplace I can go to get a diagram
Things You'll Need:
  • Replacement Headlamp 60/55W H13
Instructions
  1. Open the hood and find the front headlamp assembly.
  2. Depress the black tap holding the harness connector to the headlamp assembly. Pull the connector toward you to remove it.
  3. Turn the bulb assembly counterclockwise and remove the headlamp from the car.
  4. Check the new bulb against the old bulb for an exact match. The wattage and rating should be the same or the headlamp may not work correctly and could damage the vehicle.
  5. Insert the new bulb into the assembly and turn clockwise.
  6. Reconnect the harness connector by firmly reinserting it into the back of the assembly.
  7. Turn on the headlamps to check the alignment of the replaced bulb.
Tips & Warnings
  1. Vehicle headlamps can get extremely hot, make sure the lights are off for a significant amount of time before touching them.
  2. Halogen bulbs shatter easily, so handle with care
Nov 18, 2009 | 1998 Mitsubishi Eclipse
Got a 2000 chevy 3500 express van how do i get the old ignition switch out to replace it
remove the steering wheel , need a puller and locking ring tool, disconnect batt, turn the key to tho on position, and remove bolt that holds the tumbler in,
Nov 13, 2009 | 2000 Chevrolet 3500
Replace right rear break light
PLEASE DON'T FORGET TO RATE!!!
Signal & Marker Lights Removal & Installation Rear Lamp Assembly Sedan To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the luggage compartment quarter trim panels.
  3. Disconnect the rear lamp assembly electrical connector.
  4. Remove the lamp assembly mounting nuts.
  5. Pull the lamp assembly away from the body.
  6. Disconnect the rear lamp assembly bulb connectors.
  7. Remove the rear lamp assembly.
To Install:
CAUTION
To prevent water from entering the luggage compartment, make sure the rubber grommet is fully seated.
  1. Position the rear lamp assembly near the body and connect the bulb connectors.
  2. Install the lamp assembly into the body.
  3. Install the lamp assembly mounting nuts. Tighten to 53 in-lbs (6 Nm).
  4. Connect the rear lamp assembly electrical connector.
  5. Install the luggage compartment quarter trim panels.
Jul 16, 2009 | 1998 Ford Taurus
Left rear turn signal bulb is burned out.
Tail Lamp Assembly
To Remove:
  1. Open the rear compartment.
  2. If equipped, disconnect the cargo net.
  3. Remove the wingnut and pull back the rear compartment trim panel.
  4. Remove the wingnuts from the tail lamp assembly.
  5. Remove the tail lamp assembly from the rear body panel.
  6. Disconnect the electrical connector from the tail lamp assembly.
  7. Remove the tail lamp socket by turning counterclockwise.
  1. To Install:
  2. Install the tail lamp socket by turning clockwise.
  3. Connect the electrical connector to the tail lamp assembly.
  4. Position the tail lamp assembly to the rear body panel.
  5. Install and secure the wingnuts that attach the tail lamp assembly to the body panel.
  6. Position the rear trim panel to the rear compartment. Install and secure the wingnut.
  7. If equipped, connect the cargo net.
  8. Close the rear compartment.
      Please don't forget to rate !!!!!!
    Mar 28, 2009 | 2002 Buick Century
    Need to replace headlight assembly on 2005 Ford Escape
    ithere are 4 bolts that hold it in...the top 2 are obvious..the others are behind the bumper. the bumper must be removed to acces them...here are the manuals instructions..
    Item Part Number Description 1 — Headlamp assembly bolts (3 required) 2 — Headlamp assembly nut 3 13008 Headlamp assembly 4 14290 Electrical connectors
    Removal and Installation
    NOTE: Make sure the headlamp switch and the ignition switch are in the OFF position.
    1. Remove the front bumper cover. For additional information, refer to Section 501-19.
    1. Remove the 3 headlamp assembly bolts.
      • To install, tighten to 5 Nm (44 lb-in).
    1. Remove the headlamp assembly nut and the headlamp assembly.
      • Disconnect the electrical connectors.
    1. To install, reverse the removal procedure.
    Jan 01, 2009 | 2005 Ford Escape
    Washing Machines Logo
    19 people viewed this question
    Top Washing Machines Experts
