Question about Panasonic PT-51HX40 51" Rear Projection Television
Pt-51hx40 the tv has blurry text and is very annoying .is this a serious problem and how do i fix it .ive adjusted covergence but no luck .checked cable lines and box.i really need help before i go cross eyed lol thanx
    Genius:
  • 1,694 Answers
Needs convergence circuit repair = usually about 400.00......T.
Posted on Nov 08, 2007
SOURCE:
Mt pt-47wx49e is showing a blurry picture that bounces and waves. ive tried adjusting the convergence on the set but dont have a remote and its tricky to do on the set top controls but i dont think its...
Convergence chip could be lose as in solder joints bad sometimes a good slap on the TV side will straighten this out temporarily but not recommended. A service call is the best fix unless your handy at taking it apart and resoldering the chip you can find convergence kits online if you are the handy type :)
Sep 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Have aligned all the + signs already but is still out of focus!
with the original remote go into the customer menu and find CONVERGENCE---you will be able to adjust a single cross and also if you continue it will give you several points on the screen with a grid of lines----what you are looking for is does the red and blue adjust in all areas----if either will not adjust up/down and left right---you have a convergence problem--need to replace both convergence IC's and then align the convergence. Hope this helps you.
Aug 09, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-51HX40 Wont stay on
could possible be bad conections
I had a set that was doing that the bad conection was at the relay but you always check all conections
hope this helps
Jan 31, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-51HX40B
Check the board first, this it burned?
Jun 03, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Tv trouble
Stk392-110 Convergence IC's bad.....requires chassis pull &
good soldering ability.......................T.
Jan 28, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Blue and red lines..
alignment of the covergence board ,you must enter the servicemode to adjust.set on psess mute 1-8-3 .press enter to save your settings.
Aug 18, 2007 | Samsung PCN5425R 54" Rear Projection...
Panasonic PT-51HX40 51" Rear Projection Television Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
