Question about Ragalta USA Ragalta RWC-190 Water Dispenser - 5 gal 34.5" x 13" x 12.5" White
Not dispensing cold water
The green light always on and not dispensing cold water? Any tips or solutions will be greatly appreciate.
  • Ragalta USA Master
  • 17,115 Answers
Where is the leak?
Posted on May 04, 2013
Why is my water not cold
all things die and usually when we do not want them to .
Apr 05, 2016 | Ragalta Countertop Hot / Cold Water...
Junior 24i intermittent hot water heating works fine and the green light comes on when turn hot water tap but water cold
sounds like you need a plumber many tanks have an internal pipe that sends the cold water to the bottom of tank called a DIP tube plastic and they fail
Feb 23, 2015 | Water Water Heaters
Instant hot water tap - hot steam but delay and no hot water
This unit is set way too hot. The steam is pressuring the water out of the unit.
Feb 18, 2014 | Emerson InSinkErator C1300 Chrome...
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
Not hot water or heating
Good luck with the repair.
We always stand ready to support success.
Also post the brand and model number and type of product so expert can identify if you have electric or natural gas or propane energy, and identify if there is basic information online about your product.
Aug 24, 2012 | Water Heaters
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
The pilot on My atwood water heater will not stay lit after I release the knob. I have replaced the thermocouple and have a nice blue flame.
Did you make sure the connection between the thermocouple and the control is tight and that the tip of the thermocouple is in the flame?
Jun 28, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Ragalta USA Ragalta RWC-190 Water Dispenser - 5 gal 34.5" x 13" x 12.5" White Logo
43 people viewed this question
Top Ragalta USA Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Ragalta USA Water Heater Expert? Answer questions, earn points and help others
