I'm trying to find a schematic for the vacuum lines for my 1990 RX7 GXL with aftermarket turbo motor in it. I'm trying to make sure all the lines are hooked up correctly because i gain and lose boost regularly.
SOURCE: 1988 mazda rx7 turbo
make sure you tune it up well and take your time with it you can all so add a bit of ATF in to the spark plug hole. it help lube yes it going to smoke be it ok.i work on them for a for a living from stock rebuild to full racing.
SOURCE: Changing front door speakers in 1990 Mazda RX-7
The size of speaker that will go into that vehicle is a 6 1/2". You will need to take off the door panel in order to remove speakers. Once door panel is removed, locate screws holding speakers and remove and reinstall new speakers.
SOURCE: Mazda rx7 93 looses power @ 7k+
Look for restrictions in the intake air and exhaust systems. Check fuel pressure and delivery (fuel filter/pump). Check the ignition system as well. If the engine has a lot of miles, you may be experiencing combustion seal wear. These are amazing engines when they work correctly! Good luck!
