Set ltr paper - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
What make and model printer?
Posted on Apr 30, 2013
Paper keeps jamming
I would look to see if the paper tray's Dials are set to the correct paper size as the paper in the paper tray.. LTR size set to LTR or LTR-R set to LTR-R if the dial is set to the wrong size the copier will jam all the time. Due to a timing issue, the copier thinks it has one size, but actually is try to make a copy on different size... Good Luck
Jun 08, 2012 | Canon imageRunner C3100N Copier
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
We tried printing and copying with the setting set at LTR and LTR-R and we checked the paper tray and every time we make a copy or print it prints out the entire document perfectly centered across the...
It seems to me to be a problem of the Blue paper cassette size dial is set wrong. First see what the settings are from the display by pressing the paper select button. Most people have it set for the upper cassette to be LTR ( 8 1/2 X 11 inch paper - length running from front to rear in the cassette ) and the lower cassette to be LTR-R ( 8 1/2 X 11 inch ) or Legal ( paper length running left to right). Check to make sure the blue dial agrees with what's in the cassette. Try doing the testing by putting the paper on the glass first and closing the top. If this is correct and the problem is in the Documnet feeder then one of the raised flags may be broken or the sensor bad. The left one is for letter, the second one for LTR-R or legal and the third is for 11 X 17. The opening and closing fo the side guides also helps to determine paper size. Hope this helps you.
Nov 30, 2010 | Canon imageRUNNER 2270 Copier
Our Canon imageRUNNER 2270 is copy/printing sidways instead of normal. what happened?
I would look to make sure the paper tray's are set correctly in the paper trays... There is a knob that moves at will.... just kidding... Make sure that when you press on the diplay for paper size's, that if it shows LTR make sure the paper is in the tray going the short way.. LTR or you may have the paper tray set for LTR-R and you have the paper in the tray as LTR. I believe that the paper trays are set wrong. You may have figured it out already.. Good Luck
Nov 29, 2010 | Canon imageRUNNER 2270 Copier
I have a canon 4350d printer when i give print it asking for current paper size in every print
you can define this size in it's driver property,,,,( settings--printer and faxes--canon--properties)
Apr 27, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
How do you set it to print in LTR instead of
Inside the paper cassete there is a dial were you can set your papersize.It is a blue manual switch switch it to LTR instead of LTR -R.There is also a document stop that you can remove to set it to the correct paper size.If you print from your document select portrait insted of lanscape.
Thanks for your support.
Dec 28, 2009 | Canon imageRUNNER 2270 Copier
Prints are only at 80%
make sure your paper is not set to "ltr-r"or "letter r" which is the same size paper, just turned the other way. The control panel should show you the paper size its set for, or you can turn the original sideways if the platen/target glass allows for this size. This machine is a digital copier, so it should be able to turn it the proper direction unless its programmed for "ltr-r" copying.
May 26, 2009 | Sharp AR-164 Copier
Paper fold
What size paper are you using LTR or LRT-R? You may need the regisration clucth & the pre-regisation clutch to solve the problem, it is a timing problem with the two clutchs. If you are using LTR size paper and it shows up try runing the paper the LTR-R direction, the copier runs slower with that size paper and it may off set the timing. You may also have to clean or replace the transfer lift unit, only if you get a error code. Good Luck
Nov 07, 2008 | Ricoh Aficio 450 Copier
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
jasbo
jasbo
