TV Remote Not Working
Not working, I explain in video
    Sergeant:
  • 330 Answers
The corrosion from a leaking battery forms into a hard deposit on the contacts. That stuff has to be scraped off (gently ) in order to have proper contact with the batteries. If the problem persists, it might mean that some of that corrosion is also on the circuit board inside. I would then buy another one. Your best bid is to buy a universal remote of a decent quality. Good luck and post your results if you please.
Posted on Apr 30, 2013
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
WHICH UNIVERSAL REMOTE CAN USE FOR THE KOGAN HD TV?
Try procedure to program remote without code.. Look manual how to do it, it's different doe each remote
Jul 05, 2014 | One For All URC-3021 Remote Control
Dish Network remote and receiver problem
Hi Tracy, my name is Mike Houston a Social Media Representative at DISH. With the TV2 remote working for both TVs, you will want to make sure the TV1 input on the receiver is connected to the TV cable (RCA or Coax cable) and TV2 input is connected to TV2 port on the back of the receiver. I will provide you our link explaining in more detail about connections. If you have any further questions I will provide you my e-mail; michael.ouston@dish.com. Here is the link I promised you: http://www.mydish.com/support/same-video-2-tvs
Aug 02, 2012 | DISH Network DVR-625 DTV Receiver /...
I have a cable running from my set top box to another tv. Although i have a good picture there is not enough volume on the sound. It has worked perfectly well until I had to dismantle everything . I have a...
This is not how you explain your problems to others. It should be precise. In this case, you could have said that you connected the cable between the RF out put of set-top box and RF input TV. Or Audio/video output of set-top box to Audio/video input of the TV. Also you did not mention, to which port you had connected the Vedeo recorder and DVD which are working good. Now, it may the volume level of the set-top box at low level which you can try to increase by using the remote control
If you could not sort out the problem explain how you had 'dismantled everything'
Apr 12, 2011 | Sharp 25N-M100 25" TV
Lost manual need to know how to set remote to tv
You need 2 things to program your remote to your TV, the programming instructions and the correct code for your TV brand. There are 4 different methods for programming the remote, which are explained in the following videos:
Direct code search:
http://audiovox2.info/videos/rca_acc/new_intro.html
Auto code search:
http://audiovox2.info/videos/rca_acc/auto_code.html
Brand code search:
http://audiovox2.info/videos/rca_acc/brand_code.html
Manual code entry:
http://audiovox2.info/videos/rca_acc/manual_code.html
Sorry, but there is too much information to list it all here so it's much easier if you watch the videos. You will need to have Adobe Flash Player installed on your PC to view them:
http://get.adobe.com/flash/
Please note, your remote is fairly old and if you are requesting this information in order to program your remote to a NEW TV, the code searches and manual code entry are NOT guaranteed to work.
If the code searches don't work, it's unlikely that your remote can be used with your TV, but if you need to use the manual code entry method, you can find the codes for all TV brands here:
http://rcaaccessories.com/remotefinder/?sku=RCR311B&productType=TV
Regards,
BElectric
Nov 18, 2010 | RCA RCR311B Remote Control
Programming Daewoo tv to Comcast remote
You have this backwards. The Comcast remote control theoretically contains codes applicable to your Daewoo TV, but as you have found, it doesn't. This explains why code search doesn't work. You may have to resort to using two remote controls.
Dec 30, 2017 | Televison & Video
Replacement Sony RM ED009 remote not working
Remote sensor on the tv may not be working. Try using a camera by aiming the remote IR sensor of the remote control at the camera lens then press and hole any button and check if you see a flicker of light. If you do, the remote control is transmitting, if not, the remote control is not working. This will tell you if the remote sensor on the tv is not getting the signal from the remote control
Aug 30, 2009 | Sony Televison & Video
Remote stoped working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Dec 23, 2008 | Nintendo Wii Console
Wii remote cursor does not show on TV
Your remote's infrared receiver is broken. This is why the cursor / hand won't show up on the TV. The + and - buttons operate over bluetooth, which explains why they are still working.
If the remote is under warranty you should send it back to Nintendo to repair. If not, I suggest just buying another remote as it will cost more to repair than replace.
Nov 27, 2008 | Nintendo Wii Console
Remote not working for TV
If the batteries are good try this:
If you have a video camera, set it to record, then point the remote at the video camera and see if you can see the lights blinking at the end of the remote. (The video camera can see the infrared light pulses emitted by the remote even though your eyes can't). If you see pulses then your remote is working. If not the your remote is broken.
Jan 29, 2008 | Samsung HCJ652W 65" Rear Projection...
Televison & Video Logo
2,787 people viewed this question
Top Televison & Video Experts
