Question about Foxconn NF4UK8AA-8EKRS Motherboard
Help!!!!!!!!!!! my pc wont start up and just beeps please help me!!!
    President:
  • 317 Answers
You have a corrupt OS, assuming you have XP, you should do a repair installation. Don't worry, none of your files or settings or installed programs will be deleted. You may have to reinstall some old device drivers though. * Insert the XP CD and boot to it * When you see " To setup Windows XP now, press ENTER", go ahead and press ENTER * You will now see an option to repair Windows by pressing "R". Do not select this option - it will only take you to the Recovery Console which is not what we want to do. Instead, choose to continue the installation * When you see the license agreement, press F8 to agree * On the next screen make sure your current XP installation is selected and then press "R" to repair XP * At this point XP will begin to install on top of itself, replacing damaged, missing or altered system files. Follow the instructions on the remaining screens to complete the Repair Install. It will look very much like a normal (new) OS installation. If all goes well your repaired XP installation will remain intact, keeping your personalized settings and installed programs as they originally were.
Posted on Aug 07, 2007
    Problem Solver:
  • 6 Answers
You may want to remove the cmos battery for at least 15 - 20 minutes from the motherboard. afterwhich, you can put back the cmos battery and try and restart your computer in safe mode.
Acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one long beep repeated
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 13, 2011 | Acer Aspire™ T180 PC Desktop
My compac presario PC SR5510F keeps beeping and wont start up? do you know why that would be
When a PC is turned on and then starts beeping, the beeps are actually a message to help troubleshoot. You should listen to the beeps and learn what the pattern is. With that pattern, you may be able to determine the issue.
HP has published a list of these beep codes that are common to many of their system. That information can be found at this link > HP/Compaq Beep Codes
Feb 03, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
My PC wont start up, all it does is beep constantly. I don't have any idea what to do. Please can you help?
Beeping when the computer first starts up indicates a hardware failure. It can be bad memory, bad motherboard or something else is bad.
You can look up the beep codes from your computer manufacturer's website under support or Google It.
If you are not able to replace memory or motherboard on your computer, You will need to have a computer tech look at your computer.
Sep 30, 2010 | Computers & Internet
All of a sudden the pc wont work can start the pc and it's running but just getting a beepeing noise roughly every few seconds help please. Rich
The beeping your hearing is a code, Without knowing how many beeps it's hard to tell what is wrong, But usually indicates a Power Supply issue or even a motherboard issue those are extremes it could be that your hard drive is no longer booting, Or the operating system isnt being found, Usually though that beeping is not a good sign.
I would suggest when your computer starts beeping it is time to seek help from the pc repair shop in your area check craigslist usually some adds on there for inexpensive work
Sep 14, 2010 | Dell Inspiron 530 Desktop Computer
Computer beeps when turning on and wont start up
http://www.computerhope.com/beep.htm
Its kind of hard to tell just by one beep but the site listed above will give you codes to associate with your beep and then see if any matches and the solution beside...
hope this helps...
Aug 07, 2010 | Acer Aspire™ T180 PC Desktop
Long beep on start up
refix your ram if still facing problem try alls slot one by one.
If u start your computer with 2 ram then only start it with new one also some times frequency poblem between ram
May 05, 2009 | Computers & Internet
Emachine wont start, just beeps
This is probably a problem with your DIMM(RAM) Did u recently install an extra RAM?If yes then remove it because the beep sound is due to the mismatch of frequency of two DIMM's. If not open your computer and check if the DIMM is loose just push it in and powerup your comp..Let me know if its fixed..
Oct 08, 2007 | E-Machines eMachines Desktop PC
It wont start and please help
Can you give us some details, is it displaying any error messages, any lights on, any sounds (beeps, fans), something to start with.
Feb 10, 2007 | Compaq Presario 2200 (292600-004) PC...
Foxconn NF4UK8AA-8EKRS Motherboard Logo
122 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
