Question about Battery Biz Computers & Internet
Wipro bm49xx Laptop Battery
I have a wipro laptop model number BM49XX. I need new battery for the same.
farhangM
  • 64 Answers
SOURCE: laptop battery charge
unfortunately, yes.
Posted on Nov 26, 2008
  • 13433 Answers
SOURCE: i need new battery for my laptop gatway model no is cx2610
This is the only battery I found on Ebay
http://cgi.ebay.com/GATEWAY-AHA84226004-M280-S-7200C-CX200-CX26XX-Battery-A_W0QQitemZ250358678276QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
this is a little cheaper
http://www.jpcparts.com/AHA84226004.html
another one
http://www.tamayatech.com/parts.php?g=AHA84226004
Write the part number aha... into google and have a look around see if you can find cheaper ones if needed.
Posted on Jan 19, 2009
  • 16 Answers
SOURCE: battery charging/laptop
The battery may be getting old/depleted OR some of the cells in the battery may be dead/malfunctioning.
The battery is probably still worth using for a while yet, though it will last a much shorter time than usual.
Alternatively, you could get a new replacement battery.
A remote possibility is that you are using a wrong charger for the laptop - it does not supply enough power to the battery. Please confirm it is correctly rated.
All the best!
Posted on Jan 30, 2009
  • 1684 Answers
SOURCE: Do I need a new power cord or new battery??
Are you getting any of the power lights on? There should be a LED light showing "on AC power" and another showing "battery charge". It sounds like either the ac adapter is shorted out or the power jack in the laptop is broken. If you have a multimeter you can test the charger/adapter. Put the meter on DC volts and put the red lead on the center tip of the plug and the black lead to the outside metal of the plug. You should get from 18 to about 26 volts. If you don't get anything then the adapter is bad and will need to be replaced. If you do get the right voltage reading then the laptop jack is likely broken. You can get it repaired at most computer service depots.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
Posted on Jul 08, 2009
  • 108 Answers
SOURCE: Toshiba Laptop Wont Boot.
Hi Tks_star,
You mentioned the laptop "eventually shuts off", at what point does it do this?
other than that, I'd say you are on the right track- most likely (but not in all cases), the new AC adapter will probably not fix the problem. Offhand, it sounds like either the Motherboard is shorting out, or the component charging the battery is faulty to me. Either may require service by being sent to your laptop manufacturer or the store you bought it from.
It seems odd that the laptop is not starting up without a battery- most laptops i've looked at are capable of running on only AC power.
Posted on Aug 03, 2009
MY WIPRO LAPTOP MODEL NO.BM49XX WIFI IS NOT WORKING
Last but not least, there is no WiFi router close to you, to connect to. You don't say anything about your WiFi router here. Did you set it up it yourself? When you don't have a router, you can't connect.
Jan 30, 2015 | Computers & Internet
Invertor problem bm49xx
It is easy to replace the inverter, unfortunately it is not easy to replace the back light. It is time to replace the whole screen.
Feb 18, 2014 | Computers & Internet
My wipro BM49XX touch pad is not working how to solve
If the touch pad is not working I would recommend buying a mouse that can be connected via a usb port. Mouses of this sort can be found as cheap as 1$
Nov 05, 2013 | Computers & Internet
I can not clear password in CMOS/BIOS setup in my Laptop.
You must take out the CMOS battery its normaly located somwhere under the keyboard. When its out with power removed use somthing metal to touch the pins together on the board where it plugged in. (If you arent game to do this then just leave battery out for an hour or so) Here is pictures of different batteries so you know what they look like.
http://images.google.com.au/images?gbv=2&hl=en&sa=1&q=laptop+cmos+battery&aq=f&oq=
If you want more specific instructions then ill need a laptop model number.
Apr 26, 2009 | Acer Aspire 3680 Laptop
Wipro Laptop Driver
I HAVE WIPRO LAPTOP,MODEL :WIVNB7B1600,I FORGET BIOS PASSWORD........PL SOLVE MY PROBLEM
Jun 22, 2008 | Computers & Internet
Driver for Wipro Laptop
I have wipro laptop model no WIVNB7B1620. i have not driver for it. please help me.
thanx
Jun 22, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
46 people viewed this question
Top Battery Biz Computers & Internet Experts
justwinwin
Lawrence Oravetz
Greg Baldwin
Are you a Battery Biz Computer and Internet Expert? Answer questions, earn points and help others
