Question about Bissell SpotBot Robotic Wet/Dry Vacuum
SpotBot: all lights flashing!
I've owned a SpotBot for a year now, and have loved it. I haven't used it for a month or so, and tried using it today. In both the "set-in stain" and "surface stain" modes, which I use all the time, the machine will run for abut 5 seconds, and then it will stop and all of the lights on the machine flash. If I use the machine in manual mode, which is not the way I want to go, it doesn't do this. I tried calling the 800 line but got the standard "you'll need to take it in" reply. Does anyone have any ideas? Many thanks! Michele
  • 5 more comments
  • Dave Agius Nov 21, 2007
    I have the exact same problem and got the exact same answer.
  • Mel3540 Nov 25, 2007
    i am having the same problem as the other 2 people are
  • Sarah Louise Dec 18, 2007
    This is the same as what is happening to my 3 week old machine. Got the same answer too.
  • jad1205 Apr 27, 2008
    I have the same problem. Has anyone taken it in? Is it worth having it looked at?
  • MelissaGR Apr 30, 2008
    All lights flashing, constant beep, after being turned on for only a few seconds. User's guide is useless for this problem.
  • Anonymous May 31, 2008
    Same here. This is my third SpotBot. The first one was DOA out of the box (would not spray), and Bissel replaced it. 1-1/2 years later, it stopped spraying again, so I bought a new one. 2 months later I get the all lights flashing in automatic mode. Methinks Bissell has a quality control problem.
  • Michael Aug 27, 2013
    there is a magnet in the hose behind a plate and screw, remove and inspect. water probably destroyed the magnet. replace with a strong one from a craft store. problems solved.
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
Posted on Jun 07, 2008
    New Friend:
  • 3 Answers
There is a small magnet in the end of the suction hose. It may need to be replaced. If you could hold a small strong magnet over where it would sit when the hose is clicked in that would tell you if replacing it will help. I don't know how contact cleaner did anything for the poster above. It is a sealed magnetic switch, which is the safest way when working around water.
Posted on Dec 20, 2012
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
Had same problem as stated. Defaulted into manual mode when switched on with suction hose plugged into base. If you stopped it and pressed either auto modes it ran 5 sec and stopped with beeping and all led's flasing in sync.
I used electro-contact cleaner spraying with small tube attached to can spray nozzle. You can purchase this from Radio Shack or Auto Zone.
First I unplugged Spotbot from electric outlet. Then I sprayed into opening around all the buttons on panel and also the switch just inside suction hose connector tube on base where you have it for auto functions.
I waited 10 minutes before plugging Spotbot back in to let contact cleaner evaporate. Working fine now all modes. I believe the switch inside to suction hose holder on base could have been doused in disconnecting and seal there around switch may be less than effective, you could do that switch first and move on to control panel buttons if first switch cleaning does not correct the malfunction.
Posted on Jul 04, 2008
I do not know if this was the reason why my machine would start up for like 3 seconds and then start beeping and flashing, but all I did was pull the plastic cord wrap part out all the way and the machine was fine!
Posted on Mar 07, 2009
  • Jeff Bastion
    Jeff Bastion Dec 19, 2015
    Mine did the exact same thing, and it was my first time ever using it so I knew it wasn't because it was dirty or any of the other suggestions. I figured I had got a bad unit and then I unwrapped the hose and it worked!Thanks for the tip :)
    New Friend:
No drama here. I called the 800 # and was given the name of the service center. I read the posts here and tried the wand mode. That worked fine. I replaced the hose making sure that the hose was securely clicked into its place and it now the automatic features work like a champ!!!!
Posted on May 13, 2016
    New Friend:
I shook it a little and kept on pushing resume, and it started working. There was something in the house and it cleared on the process.
Posted on Jan 10, 2015
After a somewhat messy "not pee" stain. I found the dirty water gasket clogged as well. I then cleaned that out but found that it still flashed after a couple of seconds...so I just kept hitting resume/pause for about 10 times. In my case it seemed like the vacume line was clogged and after the 10th time it must have cleaned itself out and is working agin. (now there was at least some waste water flowing into the tank so it wasn't a complete clog...so you might want to check the hose and make sure there isn't a major clog. But for those extreamly messy stains I might want to start manual or at least make sure there is no real solids to clean before I set it on automatic mode.
Posted on Jun 12, 2008
    President:
  • 1,673 Answers
One thing is this unit has a 1 year warranty, so if less, then take it in for repair. Make sure that any filter on it is clean, and hose and tanks are in place. The circuit board may be bad and isn't a replacement part, at least it isn't listed on the parts list in the manual.
SpotBot:  all lights flashing! - 45deb9b.jpg
Posted on Feb 14, 2008
SOURCE:
My Bissell Spotbot Pet cleaner stopped working. Took it out of the closet, plugged it in, No power? It worked great the last time it was used.
Well, if cycling it manually doesn't work and replacing the controller board didn't make a difference did you check the flex hose sensor? Bots won't run unless everything is clicked into place.
"Testimonials" don't continue the thread :)
I managed to dig up a copy of the service guide since I haven't owned a spotbot in years. http://evacuumstore.com/images/spotbot-repair-guide.pdf
Mar 22, 2017 | Bissell SpotBot Pet Spot Cleaner
How do I clean the spray tip on my spotbot? It isn't spraying.
if it's not been used for a long time the pipes may be cloged up or the pump may be siezed up this video will show you how to dismantle it to check inside.
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY#!
Nov 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
When i try to use it on manual the green light will flash then turn off, but works on automatic
The hose button will only work if the hose is unplugged from the side. Sounds like it thinks the hose is still in it. There is a small magnet in the end of the hose. Over time they rust and come apart. Bits may be stuck to sensor where hose clicks in on the side.
May 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
My Bissel Spotbot will only let me use the Manual Mode, when I try to push "Set in Stain" or "Surface" stain the light won't turn on. My children were playing with it, but I...
There is a small magnet in the end of the hose. Under the phillips screw and plastic cover. Mine rusted to bits and stopped tripping the switch. A bit of a super strong hard drive magnet siliconed back in the end of the hose and all was fine.
May 26, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
Unit starts and immediately shuts off
it has a bad circut board it is a defect and bissell will replace it
Dec 13, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell spot bot will not run
I returned it. I didn't see why I would have to pay you to fix a problem when It came broken. please take me off your list.
Thank you
Jun 14, 2009 | Bissell SpotBot Hands-Free Compact Deep...
Where is the filter on the Bissell Spotbot?
#17 is a brush, #10 is the pump #2036659. If there is a filter, it is probably on the tank inlet. Most times when these units go bad, running a mix of water and vinegar to free up any clogs sometimes will fix things. If not, replacing it may be your cheapest option.
May 31, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
User guide
You will need Adobe Reader to read/print these manuals
Use the following link and click Get Adobe Reader
http://www.adobe.com
There appear to be two models the user guides are in the right column -- be sure the models are right the model numbers 1200-a and 1200-B appear under specs
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=spotbot+1200
Dec 22, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
5,855 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Marvin
Marvin
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
