Question about LG 42PX5D 42 in. Plasma HDTV
Tv pops on and off constantly for no apparent reason
    Top Expert:
  • LG Master
  • 75,581 Answers
Try first by make it a hard reset. If it do not help you, check and replace the main digital processor board. Unplug the TV AC mains wall socket, and re-plug it back after 5 minutes or so. This must make it a hard reset. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
Nearly constant static
Your cable or phone jack connection is defective.
Mar 12, 2014 | Sony Mdr7506 Professional Large Diaphragm...
At boot-up, HP Digital Media Archive pops up for no apparent reason. Cannot find a way to prevent it.
Have you tried using msconfig to see if it is listed under startup programs? If it is listed you can uncheck it and it will no longer load at start up.
Aug 13, 2011 | HP Pavilion Media Center TV m7330n...
My 42 inch flat screen was on and the all of sudden there was a big pop and the TV went blank. I could hear it clicking inside after this happened. Pulled the power plug to stop it. What caused the big...
It sounds like one of the Electrolytic Capacitors in the TV has gone, this can be caused by voltage fluctuations, Ambient Temperatures around the TV and sometimes they just fail for no apparent reason. If you are handy with some basic electronic tools you could open the back of the TV and you would possibly see the remains of the blown component as bits of paper like material around where a capacitor used to be.
Oct 25, 2010 | Samsung Televison & Video
OK so I own a 95 VW Golf 2.0 manual trans. Once in a great while it severely jerks when I accelerate or maintain a constant speed. If I give the car A LOT of gas it doesnt do it, but will continue when I...
This can be caused by a faulty throttle position sensor (TPS). It will normally be found on the end of the throttle shaft oposite the cable connection. They are fairly simple to replace, and cost less than $50.
Sep 29, 2010 | 1995 Volkswagen Golf
Volume pop-up
may be the volume up button is jammed in the pressed position....just try pressing it and try releasing it from the current position....
May 04, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
I have a 2004 silverado 1500...the air bag light "popped"on for no apparent reason the fuse keep's popping some times the fuse work's and most of the time the fuse pop's i checked under the seat and it all...
There is a clock spring under the steering wheel that provides power to the drivers airbag when turning the wheel, those are known to go out or get a short in them. Take the vehicle to Autozone and have them pull the codes for you to see which bag or sensor is causing the light. As for blowing the fuse I am leaning towards the clock spring since it is prone to high wear from constant turning of the wheel. Hope this helps.....
Oct 21, 2009 | 2004 Chevrolet Silverado 2500HD
Tv shuts off for no apparent reason
one of your circuits is getting too hot maybe the flyback is going bad,,,one of the two is wrong
Dec 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F35730ST 36" Home Theatre TV
These sets have a problem with a deguase curcuit this will blow the fuse for no apparent reason. If this is the case a thermail #207768 will need to be replaced
Feb 13, 2008 | RCA F36650 36" TV
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
141 people viewed this question
