Question about Car Audio & Video
Can't set the gain on my sx 1250.1kicker amp
I have a 12" d4 type r 1000 rms and a alpine 1000 amp speaker sounds great but smells like something is burning, my amp never over heats or shuts down but the smell is still coming from the sub?
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Apr 28, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
What size wire should i have for two 12 volfenhag subs
I would use 10 to 12 gauge wiring. As fare as your amp's fuse...Check to make sure you are using the correct amp fuse. Make sure your subs are wired to a ohm load your amp is stable with. Check your ground and positive connections. Check and make sure your amp's gain settings are correctly set. Your amp's gain should not be turned all the way up.
Sep 25, 2012 | Volfenhag ZX-4712 Car Subwoofer
2004 Dodge sx 2.0 . Wheres the fuel filter ?
So you think its the fuel filter at fault? Is the engine light ON? and what are the trouble codes?
Jun 22, 2012 | Cars & Trucks
Fosgate 1500 amp settings
low pass of course set the crossover around 80Hz. Then turn the bass down to around 35% on headunit and the volume all the way up on your head unit just below distortion. slowly turn the amp gain up until you start to hear distortion, then turn it back down until it's completely gone. Then, lower the gain just a little more to make sure you keep out the distortion on all songs. From here you should be good. If the gain is still to high. The adjust to your taste. Just don't move the bass up on the headunit or the gain past your distortion point.
May 22, 2012 | Rockford Fosgate Car Audio & Video
I got my hands of a Sharp Power Amp SX-9800. It has a power cord and a set of RCA jacks (1 red, 1 white) plus two bare wires (no jacks or connectors). It has several speaker outlets. How do I hook this...
Which is it 9860 or 9800? (No web search hits for the 9800).
JVD Tuner?
The RCA jacks on any amp so-equipped are for any external Line Level source like a tuner.
In any 'connection' question there are at least two participants and specific answers require specific details about all joined equipment.
Type carefully if you want good answers.
Sep 23, 2011 | Sharp SX9860 2-Channel Amplifier
I have a mono amplifier hooked up to a 12 inch sub. I have everything hooked up. The ground is good. However, when I turn the gain/level up to around 55% the sub starts thumping loudly. Just a rhythmic...
There are a few things you can look at. Check to make sure you power is at a constant 12 volts. Usually a dip in voltage will set off a protection mode, but it protection is malfunctioning, this may be occuring. You also may need a larger guage wire for power and ground, depending on how many amps your amplifier is drawing. You subwoofer may be the problem too. Is it a dual 4 ohm, or dual 2 ohm? If it's dual 2 ohm and your amp isnt' one ohm stable, this could be causing the amp to overload. From your description it sounds like the amp is "clipping", so my gut tells me it's more of a power problem. Recheck all your wiring. If you have a multimeter to check your power, use it. Good luck.
Sep 02, 2011 | Car Audio & Video
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
Hi i have an aprilia sx 125 it is a 2010 model and i bought it a few weeks ago it came with the warranty book but no service stamps in it. My problem is that when running the bike mainly in 4th gear at...
Hi, Dunhills and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2 Smoke questions
http://www.performanceforums.com/forums/archive/index.php/t-67251327.html
APRILIA RS 125 Workshop Manual
Products at Aprilia Genuine Parts Aprilia Parts Aprilia Spare Parts...
http://mybikemanuals.com/aprilla/2010-aprilia-owners-manuals
May 09, 2017 | 2008 Aprilia SX 125
We are getting a buzzing from our sx ga1065 guitar amp. this set is brand new. help
A fuse is probably blown...or an element is out. Can you return it where you bought it? Try opening it and checking all of it's components.
Apr 21, 2011 | Sx Guitars SX GA1065 / STCAD 10 Watt...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
