Question about Kitchen Appliances - Others
Silvercrest glass kettle
My kettle hs gone black around the edge at the bottom
3 Suggested Answers
SOURCE: Broken glass kettle
buy a new one
Posted on Jul 18, 2010
ruthfbrig35519
  • 81 Answers
Hello. Broken glass kettle is a real serious issues and those are not easily replaced as well, but I know a place where one can find all their relevant answers and for this, they just have to click at the below link: Top 5 Best Electric Kettle
Posted on Jul 23, 2015
What are the advantages of using clear glass kettle?
Clear glass kettle are attractive, easy to pour from, and refill because of its large top opening. You will find many good functions on the advanced clear glass kettles like Breville and Cusinart. Cleaning the scale deposits from the inside is easy and much more.
Get some more details here: Top 5 Best Electric Kettle
Jul 28, 2015 | Kitchen Appliances - Others
How to replace a driver side door glass on a 2000 ford winstar
Remove the door panel. Look for screws around the edge and at the arm rest and handle. After there out pop the panel off, pry at the bottom first and work your way around. Then you'll have access to the window regulator and glass. remove the trim at the bottom of the window opening to remove or install the glass.
Jul 19, 2015 | Ford Cars & Trucks
Russell hobbs problems
Hi Naomi,
please check the manual.and see if it is has a small hole or opening in kettle to go to outside of steam.
your one must be blocked .
regards.
nuwan
Jan 13, 2014 | Toastess Cordless Electric Glass Kettle...
Oster water kettle leaking from bottom of unit when pouring?
If you're not just simply missing the opening a little as you're pouring then I'd assume it's cheaper to replace than to repair, sorry.
If it's leaking from the side-glass you might get by with filling your kettle just under the lower end of the side-glass.
May 29, 2012 | Oster 5965 Electric Kettle
Hello Is it possible to remove the glass door panels for cleaning? I can remove the door but I want to clean the glass panels separately. Many thanks Jill
With the door removed, I would suggest to lay it on a flat surface, look at the door around the edges. Normally you can see 2-3 screws around the bottom and 2-3 screws around the top edge. By removing them you can disassemble the door. Be-careful as you disassemble the door, pay close attention to how it can apart to reassemble when your done. This job should not require any special tool other then a screwdriver. Do not force anything back together. This should be about a 30-min job or less depending on the cleaning part on the glass. Go luck.. P.S. - it is glass your dealing with, some of the edges can cut you if handle in the wrong unsafe manner.
Jul 08, 2011 | Whirlpool Ovens
Black & Decker electric tea kettle leaks.
CALL Black & Decker Customer Service at 1-800-231-9786 and they will replace the unit. They will ask for the model number CK1500R from the bottom of the base and the number on the prong of the plug, mine was 626XO. They will ask you to keep the old one until you receive a letter from them about what to do with the old kettle and the new one in a separate box. All free. Cool.
Jan 11, 2011 | Black & Decker Black Decker Brushed...
Can glass kettle be used on glass hot top stove?
No you should not use a glass kettle or glass type pots on a ceran top stove. Always use metal flat bottom kettle and pots. When buying a metal kettle make sure that there is no gap between the bottom of the kettle and the surface of the ceran top. Some metal kettles have an indentation on the bottom. This does not work well on the ceran top.
Hope this helps.
Dec 30, 2009 | Kitchen Ranges
Kitchen Appliances - Others Logo
29 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
