Question about JRC Boating
Txrx scanner txrx HL SCANNER ALARM CODE 312
3 Suggested Answers
  • 114 Answers
SOURCE: Brother HL-6050DN Printer gives "replace laser sca...
The problem coming because the laser unit in your printer is not working . Need to be replace laser unit to solve the problem.
Posted on Jul 21, 2010
xptareq2029086
  • 169 Answers
need to reset .Open the front cover .hold the go button power on all lid on than press 7 time .on off printer may be reset.
Posted on Jan 11, 2018
HOW DO I RESET ABS ALARM
Disconnect the battery for a few minutes then re-attach. Or, call a local auto parts store and they most likely will read the code and clear it for you. also you can buy one obd2 scanner read and clear the fault coder by yourself if u mean the loud noisy horn alarm
DIY car obd2 code scanner online shopping
Sep 18, 2014 | Cars & Trucks
How do I delete documents waiting epson-xp-312
Goto printer on your computer and press stop or del
Aug 29, 2014 | Epson Expression Home XP-310 All-in-One...
Error code "L"
Is the code display L-6? This error code describes US Sensor Alarm.
You may perform the following steps or may ask your local Fujitsu scanner expert for the disgnosys and replacement of faulty part.
1. Does the same symptom occur after turning OFF and ON the scanner? To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check the US Sensor operation by conducting Maintenance mode to see if the US sensor works properly. If the error still occurs, confirm that the sensor cable is correctly connected. And then replace the US Sensor FX and US Sensor RV.
Thanks & regards,
ScanCare
Aug 05, 2013 | Fujitsu fi-6130 Flatbed Scanner
Backside Optical alarm (G) when using Duplex option
Hi Rasha,
ADF backside scanning optical alarm (upper optical unit ADF) is E3 alarm. When there is an irregularity in the amount of light (ADF back), "E" and "3" will be displayed alternately on the function number display panel of the scanner.
Please check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2. Is the lower glass (white sheet guide) of the reading section dirty? Open the ADF, and clean the sheet guide (white part) and the glass.
3. Is the upper Optical unit ADF dirty? Are the cables damaged? Are the connectors connected properly?
4.E3: Is the upper lamp ON? Are the cables damaged? Are the connectors connected properly? Disconnect the SCSI cable and turn the scanner ON. Open the ADF and press ADF cover open sensor as shown below to see if the ADF lamps light which has to be replaced.
I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 12, 2013 | Fujitsu fi-4750C Flatbed Scanner
What is code 71 on brother hl 4040cn?
I cannot find a direct reference to this model, but the 71 error code in Brother printers usually refers to a problem with a scanner motor. These issues usually require the replacement of the scanner motor.
Mar 29, 2011 | Brother HL4040CN Laser Printer
Scanner driver
http://74.125.153.132/search?q=cache:GQmHQ4GjqF8J:www.downloadsource.net/17564/UMAX-Scanner-Astra-3600-Driver-Windows-98SE-ME-2000-XP/+astra+3600+DRIVERS&cd=1&hl=en&ct=clnk&gl=in
Mar 30, 2010 | Umax Astra 610P Flatbed Scanner
Scanner won't work
How to use the scanner with a black ink cartridge install and no color ink cartridge install, plus the alarm light is on
Sep 13, 2009 | Canon MX300 Office All-In-One Printer
Door open
There are quite a number of sensors in any scanner. Sometimes shreds of paper get stuck inside the scanner and create a false alarm like this. Blow with a vacuum cleaner and try. wipe clean the sensors. Dont use solvents.
S. Mohan, Chennai. India.
Nov 13, 2008 | Canon DR-2580C Path-Through Scanner
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Boating Logo
20 people viewed this question
Top JRC Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a JRC Boating Expert? Answer questions, earn points and help others
