Question about Sewing Machines
Brother vx885 sewing machine
Cotten keeps breaking at needle
yeroc
  • 397 Answers
SOURCE: needle keeps hitting the plate and breaking
possibly off timing,
Posted on Jan 21, 2008
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
My 2003 Brother sewing machine is needle keep on breaking when I try to sew
http://www.sewingandcraftcorner.com/why-does-my-sewing-machine-needle-keep-breaking
If it continues to break needles, most likely the machine has been knocked out of time. Search for sewing machine timing or take it for repair.
Mar 22, 2017 | Brother Sewing Machines
Why does my thread keep breaking on my brother ce4000? The machine is 100% threaded correctly new needle properly wound bobbin, I just don't know what could be wrong with it.
Could be a multitude of things. Use only good quality thread--no old or bargain bin threads. Try a different brand of thread--some machines prefer certain brands over others. The needle and thread should be compatible--ie needle eye shouldn't be too small for thread weight. Burr catching the thread and breaking it. Upper tension too tight.
Remove the upper thread, RAISE the presser foot and rethread from the beginning. Verify the thread is not looped incorrectly in the thread path, like around a thread guide or around the spool pin. Is the thread snagging on the thread spool itself? Do you see the thread tightening as you sew and eventually it breaks? This indicates it is catching somewhere between the needle and spool. Is it shredding at the needle eye? This indicates the needle eye is not suitable for the thread being used.
Watch where the thread is breaking. This will sometimes give you a clue where the problem exists.
Sewing Machine Problem 1 Thread Breakage
Why Does My Thread Keep Breaking While Sew
All About Needles
Jan 26, 2017 | Brother CE4000 Computerized Sewing Machine
My machine is new (only used once) but now keeps jamming, appears the needle keeps jamming under the plate,please help.
if it' still under warrenty take it back and get another..if it's not under warrenty, try a new needle, make sure the top thread is not coming off the thread take up lever, make sure the bobbin is turned the right way in the bobbin case, also could be a timing problem
Dec 03, 2014 | Sewing Machines
Needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Jul 11, 2014 | Brother LS2125i Sewing Machine
How to retime a brother 900d sewing machine
Breaking threads isn't necessarily a timing problem. Check for burrs.
Nov 11, 2012 | Brother Innov-Is 900 Sewing Machine
Needle keeps breaking HELP!
Needle breaks
I suggest contact brother.com or a dealer about the needles , cause
I've checked on the internet and on the brother site about the needles and couldn't find any information.
Jul 26, 2012 | Brother PE-150V Computerized Sewing...
My needle keeps breaking
Needle breaks
Jun 18, 2012 | Brother PE-150V Computerized Sewing...
scott
Apr 21, 2009 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5340 sewing machine
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Dec 01, 2007 | Brother XL-5340 Mechanical Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
