Question about Radio Communications
Iam install window .a/c in my house which is lancer company 1.5 ton window .when start the a/ c it runs smooth 4minits after main MCB 40 amps triped what is causes pke tell me. E L CB ALSO connect it not triped . Always main MCB triped after start 5 mints
  • 17,167 Answers
This is one of several things. The fan motor might have a bad capacitor. The unit is heating up the breaker box etc
Posted on Jun 10, 2013
Shuttle83
  • 1139 Answers
SOURCE: looking for a Maxon mcb-30 manual
I think I have the service manual for this radio please send me your email so I can send it to you
I believe the MCB-30 Crosses with the SM2500 from what I have been reading.
Posted on Nov 03, 2008
SOURCE: Maxon MCB-30 CB Raido
what do you mean program it? swr?
Posted on Mar 19, 2009
  • 24 Answers
SOURCE: mic wiring diagram 4-pin
try http://www.cbtricks.com/
they have mic wireing diagrams
Posted on Jul 14, 2009
  • 636 Answers
SOURCE: install cb in house
you will need a 12 volt converter for this
Posted on Sep 01, 2009
  • 158 Answers
SOURCE: what size fuse do i need on the positive side do i
Most un-modified CB radios run about 2 to 4 amps on transmit. A 5 amp fuse is sufficient for most radios. Check you owners manual for the correct size fuse to use.
Posted on Mar 01, 2011
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
Lights flicker or dim when 1 ton split a/c outdoor unit compresser starts & click sound appears from double booster or in MCB . ( BUT NOT DRIPPING )
Samsung units won't operate properly below 190 volts and over 230 volts. You need a transformer similar to what they use in marinas. In Mexico they use step up transformers on appliances because of voltage drops in the evening until the electric company winds up the supply.
Sep 26, 2013 | Samsung Heating & Cooling
Main breakers keeps blowing what is the reason i had the electrical company check there stuff up to the house said everything was ok no smaller breakers are blowing just the 200 main is it possible i did...
Add up all the amps from active breakers. Do they add up over 200? If not, then I suspect a bad main breaker. If they do, then you need a larger service box and or main breaker.
Sep 24, 2017 | Siemens 200 Amp Main Breaker 30 Spaces 40...
How to convert the aircondition tanage in amp
I assume you mean tonnage. If you are looking for the amp amount to run a circuit to your aircond. here is rule of thumb: 2 ton is a 20 amp circuit (requires two 20 a breakers for a 230volt single phase unit)
3 ton is a 30 amp circuit (230v 1 phase)
4 ton is a 40 amp circuit (230v 1 phase)
5 ton is a 50 amp circuit (230v 1 phase)
all these require two breakers, and both breakers should be joined together.
May 11, 2011 | Heating & Cooling
What fuse does my maxon mcb-30 cb take
12 volt 2 amp kinds or any 0.5 amps even. You want it to blow fast to save radio from damage. So, any type 0.1 amp to 1 amp or 2 even. It doesn't matter; but a fast blowing one will save radio from damage later on.
Apr 04, 2011 | Maxon MCB-30 40-Channels Base CB Radio
Wiring standard for Split AC 1.5 Ton
The factor that you have not included here is the distance from the power panel to the unit...if it is too far then you need to up gauge the wire to compensate for that... that could be why the electrician wanted to go to the 720 ga. wire.
heatman101
Apr 16, 2010 | Samsung AS18A6RB Air Conditioner
Window 1.5 AC Problem During Day
Chack size of wire. Should be at least number 10 wire. Check loose connections. Call power company to check your voltage. This time of year in different parts of the country they have brownouts which is a voltage drop becaus of the load on the lines. Have power checked. Rus
Jun 15, 2009 | Heating & Cooling
What wire size do I run for a 3 1/2 ton AC unit?
it depends on the distance from main power source # 8 if more than 40 feet look at starting amps then google a wire sizing voltage droop chart
May 08, 2009 | Heating & Cooling
Powercable gets burned
The wiring inside the walls dictate what size of amps can go through the lines. most wiring inside the house walls is only capable of carrying 15 amps. Meaning the wire size is 14 gage. You can't change the breaker size to 20 the wire can't carry that much power. You have a window A/C that requires around 9 amps. Now somewhere in the same circuit you are using some other amps, say something like a lamp it needs 2 amps. A tv it needs 4 amps say something like a computer it needs 2 amps. Do you get the idea? A/C's need a circuit all by them selves. That is why the cord is getting burnt.
And then another problem might be the connection to the wall outlet it self might be loose meaning it isn't getting all the power it needs. With loose wires it will get hot and draw power as much as it can and not get it. So turn off the breaker and check the outlet to make sure the connections are tight and clean.
I hope this helps you indentify the problem get back with me and let me know.
Apr 12, 2009 | Heating & Cooling
Electrical - Air Conditioning
Ben, you are on the right track. To upgrade the breaker, first look at the main house breaker panel and determine if allowing more current through main breaker will be taxing it too highly (will 20 more amps exceed my main breaker limit...what is the main breaker current trip at?) Then look at the wire size leading away from the 40 amp breaker to outside. If it is 6 gage copper or 4 gage copper-clad aluminum wire, you are ok to upgrade. Any smaller wire size could be unhealthy.
Sep 03, 2007 | Heating & Cooling
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
